Running two Signalink devices on one PC
Discussion in 'Computers, Hardware, and Operating Systems' started by WM5TS, Nov 26, 2018.
  1. WM5TS
    WM5TS XML Subscriber QRZ Page
    What is the best way to run two Signalink devices on the same PC? I am not running them at the same time but when going from one to the other things often get hung up. Is there a way to change the IP address in one of the Signalinks?
    Thanks;
  2. K7MH
    K7MH Ham Member QRZ Page
    A SignaLink does not have an IP address. It is not a device that connects to the internet.
    Shouldn't be a problem to have two of them connected to two different rigs on two different USB ports. You would have to change settings if there was only one program that you were using. Not sure why you would want to have two of them though.
    You might want to elaborate on just what you are trying to do.
  3. WB5WPA
    WB5WPA Ham Member QRZ Page
    The Signalinks show up as USB (Universal Serial Bus) Sound cards on a PC.
    That's it. They use a TI (Texas Instruments) USB sound chip the last time I checked.
    What you need to do, is select a different sound card in your app to address a different Signalink and radio combo ...
    WM5TS likes this.
