ad: Halibut-1
RS-HFIQ 5 Watt HF SDR Transceiver by HobbyPCB
Discussion in 'Amateur Radio News' started by M0DQW, Sep 5, 2021.
  1. WY7BG
    WY7BG XML Subscriber QRZ Page
    Nope; it is. Manufacturers of amplifiers assume that you always want to drive them to full power (even though in real life you have to scale the power back for a high duty cycle to keep from frying most of them) and so set the minimum input power so that one can do that without exceeding the FCC gain limit (or, in many cases, even getting too close to it).
    Let's put it another way. Suppose I want 300W of output power and buy a 600W amp so that I can work digital modes at half the maximum (as is recommended by virtually all manufacturers). Many such amps will require 20W or more of input power from the exciting transmitter to avoid exceeding 15dB of gain (roughly a factor of 30). So, a QRP transmitter won't excite the amp, even if it has automatic level control (ALC).
  2. WY7BG
    That's another one worth considering. Only downside is that I use a remote tuner (an SGC-237), which wants 10-12W when you first transmit on a new band to tune up. The TenTec doesn't seem to have a switch that lets you start at a low output power (possibly bypassing the amp altogether) and then go to full power after the remote tuner signals that it's found a match at your chosen frequency.
  3. AB2YC
    AB2YC Guest QRZ Page
    When I had the Tentex 418 I also had a SGC-230
    All you need to do is to disable the amp during antenna tuning
    I forget how I did it but something a simple as putting a switch
    in the PTT line between the rig and the amp would work
  4. W3ATT
    W3ATT Ham Member QRZ Page
    Try a TenTec Titan. 5w in gives me 150 out. I get 400 out with my 10w k2.
    Try a Ten Tec Titan... you'll get well over 100w out with 5 in.
  5. KC3JH
    KC3JH Ham Member QRZ Page
    W3ATT, I think your comments were mis-directed to me and should have gone to the station who my original comments were directed towards. He was lamenting the lack of amplifiers that will take 5W and produce 100W output (13 dB gain), and blaming that lack on the FCC's 15 dB amplifier gain limit, which obviously is not a factor. I was trying to demonstrate the fallacy of that argument.
  6. KB6QXM
    KB6QXM Ham Member QRZ Page
    I have been involved in SDR since the early days. Flex Radio fan. Life is too short for QRP!
    AA5BK likes this.
  7. W3ATT
    Roger that.. and while a 100w amp is good, one can get by with a readily available QRP 50w amp... going from 50 to 100w is merely 3db which is only a half an S-unit on the receiving end!
  8. KC3JH
    Thanks, and agree 100 percent on that. 50 watts (10 dB gain) is a nice step up from a 5W QRP rig. The amplifier would have a modest power supply requirement too.
    On the other end, if a manufacturer chose to, they could produce an amplifier that would supply 150W output for 5W input, with a linear gain of 14.8 dB, and still meet the FCC's requirement of 15 dB maximum gain. Such an amplifier would have a good bit of overhead for operators who would want to use it for high duty cycle digital modes at power levels around 50W.
    73 Frank W3PX
  9. KISEL39671
    KISEL39671 QRZ Member
  10. KE0EYJ
    KE0EYJ Ham Member QRZ Page
    Good stuff.
  11. KE0EYJ
    After lots of QRP work, and playing around with wattage in between, I am a fan of running at 20 to 25w. I find the difference between it and 100w is very livable.
    KC3JH likes this.
  12. PA0MHS
    PA0MHS Ham Member QRZ Page
    Of course it will happen. Wether somebody notices it, is the question. But if the RF envelope raises from oW to a certain value linearly and the bias is enabled after a certain threshold, the the RF envelope on the output of that amp will certainly not be equal to the envelope of the input. So there is at least some extra distortion at the start of a tranmission and it depends on the RC time of the bias circuit how often during one transmission of speech this distortion occurs.
    WY7BG likes this.
  13. MW1CFN
    MW1CFN Ham Member QRZ Page
    What's its frequency stability like if sending WSPR, for example?
  14. AE0Q
    AE0Q Ham Member QRZ Page
    It does happen each time, of course, but the RF output of the amp is so low that it isn't significant. The amp is putting out 5w or less at the switch.
    Alpha and Acom amps that run GU74b tubes at their max need the heat-saving in heavy contest use. Use in CW and SSB contests showed the tubes run too hot without the EBS.
    Being in Europe, you probably already know the reason the GU74B was used, there were thousands available surplus in the 90's and they were really, really, really cheap.
  15. WY7BG
    Unfortunately, you seem to fail to understand the design of amplifiers and the markets for them. Amplifiers, by their nature, must be designed to have both minimum and maximum input power to maintain linearity. Too weak a signal will cause crossover distortion or be swamped by the bias current or voltage. Too strong a signal will, of course, cause clipping or worse. The FCC limits on gain prevent an amplifier maker from setting a weak input signal as the default, and so virtually all amplifiers with capacities of more than 100W (and you want to run an amp at half its capacity for modes with high duty cycles, such as RTTY, so you want an amp rated at 200W or more to run 100W) require high drive power... at the expense of enough wasted power to keep your shack quite toasty. Were the FCC limit not in place, it would be possible to set the required input power for even a legal limit amp at QRP levels - saving energy and making it easier to obtain high power output from simple SDRs. But due to the gain limit, manufacturers can't do that.
    Most of us also know why the FCC did this: to monkey wrench CBers who wanted to use ham radio amplifiers. Commercial CB radios are limited to 5W output power, and so won't excite an amp that requires 50-90W input power. But now that the CB fad is past, and manufacturers have imposed other impediments to using amateur radio amps for CB, the limit is unnecessary and should be struck from the rules.
    AA5BK likes this.
ad: CQMM-1
