ROHN 9H50 Telescoping Mast Sections Won’t Move
Discussion in 'Ham Radio Discussions' started by K9BAY, Sep 12, 2020.
  1. K9BAY
    K9BAY Ham Member QRZ Page
    I am raising the mast As a trial run, before mounting the antenna to the mast, and sections 1, 4, & 5 move with no problem.. Sections 2 and 3 are stuck!!
    A ham friend suggested using monkey wrenches turning in opposite directions, to see if I can get it to turn/ move.
    Anybody else run into this issue?
    THANKS!
  2. KN6SD
    KN6SD Premium Subscriber QRZ Page
    WD40???
  3. WR2E
    WR2E Ham Member QRZ Page
    They probably got 'hammered' together during shipment.
    First time it's ever been extended?
    The wrenches might not be such a good idea. The last thing you want to do is to deform the roundness of the tubes. (and, if it's galvanized, the teeth will cut through that coating and you'll have spots where rust can start to form)
    I would probably try 'shaking' them loose first. Clamp the bottom down somehow and pull and shake at the same time. Be prepared to fall on your butt when they let go!
    Tug-O-War with a pair of 4WD vehicles oughta do it.
    K4AGO likes this.
  4. K9BAY
    I think I am going to call DX Engineering where I purchased it and see what my options are!
    See picture...
  5. WR2E
    That's actually a pretty good idea before you go monkeying with it and possibly damage it further.
    You might be able to drive them apart with some appropriately sized hardwood dowels.
    K0UO likes this.
  6. K2CD
    K2CD Premium Subscriber QRZ Page
    Try a little bit of lubricant and gently tap with a rubber mallet whilst pulling? Ouch, that sounds naughty. How about a blow dryer try to expand the outer section a tad.
  7. K4AGO
    K4AGO Platinum Subscriber Platinum Subscriber QRZ Page
    I agree. Monkey (pipe) wrenches are a very bad idea.
  8. KA0HCP
    Gee, in another thread about using Rohn masts, I was inundated with 'corrections" that they are "easily pushed up by hand". ;)
    K7MH likes this.
  9. K7MH
    K7MH Ham Member QRZ Page
    Yeah. I would like to get a 50ft pushup a small tribander and a rotor and drive around to each of their homes and see how that REALLY goes. See who can push it up the furthest!:)
    I would take a piece of wood and place it on the edge of the smallest one that is stuck from the bottom and hit the other end of the piece of wood with a mallet or hammer to try and loosen it and move it forward in the larger tubing.
    The wood doesn't really have to fit it perfectly just get it on the end of the tube somewhere.
  10. WB2WIK
    They usually are, but the 9H50 is a bit newer model (didn't exist 20-30-40-50 years ago) with more and shorter sections and I've actually never used one.
    The old, original H50 is five sections and extends to about 45 feet and I've pushed those up by hand scores of times, with a rotator and beam on top. Those were pre-greased at the factory (making them a bit slippery -- gloves definitely needed!) and usually slipped up and down with no issues when new.
ad: vanity
