SOLD RLC-1 Repeater Controller
Discussion in 'Ham Radio Gear For Sale' started by W5ZIT, Jan 10, 2019.
Tags:
  1. W5ZIT
    W5ZIT Ham Member QRZ Page
    This listing is for an RLC-1 Repeater Controller recently taken out of service. The controller was working properly when it was removed. This is a dual port repeater controller and it allows for linking of a repeater, full crossband repeating, or operation as two repeaters. Low current draw, ideal for solar sites. CW identification and command response. Programmable via RS-232 serial port, or via DTMF commands.
    This repeater controller consists of one repeater port, one linking or repeater port, four analog voltage inputs, four logical (dry contact) inputs, and five MOSFET output drivers.
    The repeater and linking ports can be configured to require combinations of COR and PL inputs for access. The RLC-1 has a single DTMF decoder that scans between the two receiver ports, thereby supporting DTMF control from all ports of the controller.
    Speed selectable Morse Code prompts the users in the programming of the controller's variables, and the controller is housed in a nice 1.75”x19” rack mount fully enclosed case.
    A manual for the controller is available from the Repeater Builder site under the Link Communications section.
    The controller can be programmed via a terminal connected to the serial input as well as Touch Tone input. Several input ports can monitor switch positions ect. Also several A to D analog inputs are available to monitor site conditions like voltage level, temperature, ect. Several controllable outputs are available for site control. The very complete manual explains the use of each of these features.
    Price $195 plus shipping.
    w5zit@netscape.net
  2. W5ZIT
    This item is sold
  3. QRZ
    Important Rules
    Have you read our Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
ad: NI4L-2
