RGO ONE - new HF compact CW/SSB transceiver
Discussion in 'Amateur Radio Equipment Reviews' started by OK1RP, Dec 4, 2019.
Tags:
  1. OK1RP
    OK1RP Ham Member QRZ Page
    Hi all,
    This coming new CW/SSB all HF bands transceiver is the “golden classic” architecture of 9MHz IF superhet with good filtered front-end and proper roofing crystal IF filters.
    It is using PHEMT LNA, high dynamic range H-mode mixer, 8+4 poles xtal filters etc.
    Full, fast and absolute quiet QSK with proper timing is devoted to all CW enthusiasts.
    It looks like great era of famous TenTec tcvrs is coming back [​IMG]
    http://lz2jr.com/blog/
    https://groups.io/g/RGO-ONE
    https://www.eham.net/reviews/view-product?id=14445
    Experiences with RGO ONE in CQWW, CW by John, AE5X:
    https://ae5x.blogspot.com/2019/11/cqww-cw-with-rgo-one.html
    Some pics of my new arrived RGO ONE are uploaded in groups.io here:
    https://groups.io/g/RGO-ONE/album?id=223623
    And one more think... I like very much the sentences posted by KW6LA:
    "I do like the old style controls. RGO ONE looks like a radio, not a garage door opener!"
    73 - Petr, OK1RP
    WW2PT likes this.
  2. OK1RP
    Hi all,
    last evening I found the chance to bring my new RGO ONE to our contest station in order to make first short test on the air.
    I have to say that I am impressed how the receiver is quiet. Compare to other radios and mainly SDR architecture radios the RGO ONE
    receiver has smooth and low noise. The VBF is very effective and nice feature for close in signals.
    I had only short time yesterday evening so I tested it quickly on 40m then 80m band. As I found the pile-up for T6AA on 80m I had chance also to testing the RIT/XIT features etc. It is easy to manage and operate the RIT/XIT on RGO ONE.
    Big surprise came after switching to 40m where that nite was hearable OTHR intruder at around 7005kHz. I tried to switch antenna to our
    contesting Icom IC-756PROIII quickly to found that OTHR occupied most of the CW portion in 40m band with over S9+20dB wideband mess. Even with 500Hz filter on Icom I was not able to hear any signals on 40m CW band as 30kHz far from the center I still had S8 wideband noise.
    After switching to RGO ONE the surprise happened. Of course the OTHR blasted to S9+30dB at 7005kHz and covered wide portion of CW band but when I switched the VBF ON and reduced it down to 200Hz then I noticed that when I tuned up over the 7015kHz the wideband mess gone and I was able to operate and make QSO without any problem or QRM. Amazing!
    I did not make video unfortunately as my phone battery lasted exactly at that time when I need it... but I make QSO 15kHz away from the OTHR intruder with VBF set to 300Hz and I was not disturbed at all...
    I had no more time to test it yesterday evening so more tests will come later.
    73 - Petr, OK1RP
  3. OK1RP
    Hi all,
    after posting few info about I got several emails requesting more details about the new transceiver RGO ONE coming on the market…
    I compiled all detailed info to the three parts articles here:
    http://ok1rp.blogspot.com
    73 - Petr, OK1RP
    WW2PT likes this.
  4. OK1RP
    Hi
    My experiences with VBF on new RGO ONE on CW
    Petr
  5. OK1RP
  6. OK1RP
    Hi all,
    as you know the optional module of ATU is under finishing and the f/w code under tweaking for the RGO ONE.
    One of the hardest point of the ATU performance - the very low impedance matching has been successfully tested on the beta test piece of RGO.
    Look over here:
    The antenna in use was an 80m band dipole. Tested band was 160m.
    The ATU f/w code is still under tweaking and hardware is in beta testing to be sure that all will perform excellently in RGO ONE finally.
    73 - Petr, OK1RP
  7. OK1RP
  8. OK1RP
  9. OK1RP
