RG-8 Vs RG-213
Discussion in 'General Technical Questions and Answers' started by G7GPL, Sep 1, 2008.
  1. G7GPL
    G7GPL Ham Member QRZ Page
    RG-8 Vs RG-213 (Edited to 58)
    I am sure this question must have been asked a thousand times but I cannot find any reference to it.
    Next week I shall be installing a Comet H422 HF antenna.:)
    The cable run to it will be 20-25 yards
    So bearing in mind that the highest frequency will be the 10 meter band how much difference in 'Real terms' will be made if I feed it with either [edit] RG58 (thin stuff) or RG213 (thick stuff) over that distance.
    Basically is 213 worth the extra 'coins' for my particular installation.
    Thanks in advance, Nick G7GPL
    P.S. I cannot see me ever using a tranceiver giving more than 100w
  2. W8ATA
    W8ATA Ham Member QRZ Page
    The term "RG-8" covers several (maybe 10-12) "models" of coax with RG-213 being one of them. RG-8X is a smaller diameter one also. I suggest you go to one of the websites that have charts of all commonly used coax and get loss/antenuation figures and power handling capability. Universal Radio has good charts on their online catalog under the coax tab. www.universal-radio.com I hope this helps you. I use good quality RG-213 for my three HF antennas with about 75-80' runs.
    Russ
  3. G4LNA
    G4LNA Ham Member QRZ Page
    Have a read of this article Nick http://www.a1antennas.com/FAQ.html
    It's a bit of an eye opener regarding losses in coaxial cable. Do forget the loss works both ways as well, so it's like putting an attenuator in on receive as well as transmit.
  4. K7FE
    K7FE QRZ Lifetime Member #1 Platinum Subscriber Life Member QRZ Page
  5. K9STH
    K9STH Ham Member QRZ Page
    RG8/U does not exist anymore officially as the designation was a "mil spec" (military specification) issued by the United States military. The designation has been replaced by RG213/U. As such, there are RG8/U "types" the quality of which ranges from less than dismal to excellent. This is due to the fact that there is no longer any actual specifications for RG8/U coaxial cable.
    When RG8/U was a military specification such coaxial cable had to meet certain minimum standards including the percentage of braid coverage, the type of materials used as the insulating medium, and the materials used in the outer sheath. Since RG8/U has been eliminated as a military specification all sorts of cable manufacturers are manufacturing RG8/U "type" cable and what you get when purchasing these types of cable can vary considerably in quality.
    With RG213/U cable there exists a military specification that must be met in order to call the cable RG213/U. Of course there can be a small number of manufacturers that "fudge" the quality. However, the chances of getting a quality product is considerably higher when RG213/U cable is purchased and that is assured by purchasing a known brand name.
  6. G7GPL
    Thats a very cool and useful link.
    Thanks, :)
    Nick, G7GPL
  7. K4YAN
    K4YAN Ham Member QRZ Page
  8. K7KBN
    K7KBN Ham Member QRZ Page
    As far as "thin" and "thick", both RG8 and RG213 have the same OD: 0.405".
  9. G7GPL
    Eeeeeek ..... Sorry people !!!!! :eek:
    I meant for the RG8 to really be RG58
    Nick, G7GPL
  10. K9KJM
    K9KJM Ham Member QRZ Page
    Genuine Belden RG-213 coax is still the "top" coax available for HF use. It is so tough you could run over it with a truck and not hurt it!
    But if you are careful with it, Some "mini-8X" size coax will also work OK for HF through 10 meters at a length of 75 feet or less.
    Note that those types of coax are NO GOOD for VHF/UHF at those lengths!
    A low loss feedline like Times LMR-400 is needed for the higher frequencies!
