Since renewing my Subscription in Dec Log4om will not upload my new contacts to qrz.com I also see an error with Gridtracker when using ft8 I've not changed anything at all other than renewing my subscription.. I've checked the API Key in all my programs & they seem to be the same as on here.. I need help, please..
Out of QRZ. You should always log out and log back in of QRZ after making subscription/account changes. Yes, it could affect Log4OM because if your XML subscription was renewed LOG4OM may have some old expiration value set in a cache somewhere that hasn't been renewed with a new value.
Not sure if this will help.. But when trying to sync Log4om to qrz manually I'm getting this error.. Upload failed: 'STATUS=FAIL&RESULT=FAIL&REASON=QRZ Internal Error: Unable to add QSO to database.&EXTENDED=add_qso: outside date range, ' for QSO Callsign: OE5TXF Date: 23/01/2025 09:03:00 PM Band: 40m Mode: FT8 Upload failed: 'STATUS=FAIL&RESULT=FAIL&REASON=QRZ Internal Error: Unable to add QSO to database.&EXTENDED=add_qso: outside date range, ' for QSO Callsign: EN0U Date: 23/01/2025 09:59:38 PM Band: 40m Mode: FT4 Upload failed: 'STATUS=FAIL&RESULT=FAIL&REASON=QRZ Internal Error: Unable to add QSO to database.&EXTENDED=add_qso: outside date range, ' for QSO Callsign: HA3IC Date: 23/01/2025 10:09:01 PM Band: 40m Mode: FT4 QRZCOM END
