Receives but not transmits wsjtx on big sur
Discussion in 'Mac Ham Radio on macOS & iOS' started by W4SOU, Oct 12, 2021.
  1. W4SOU
    W4SOU Premium Subscriber QRZ Page
    Have a macbook air got it to run wsjtx after some working and setup the audio codec settings properly, it receives but wont transmit.
    Error code is
    Any suggestions?
  2. K7GQ
    K7GQ Subscriber QRZ Page
  3. W4SOU
    Yes, just now, i just opened that setting menu and it was already setup to allow wsjtx access to the microphone.
  4. K7GQ
  5. DL2RUM
    DL2RUM Ham Member QRZ Page
    You have a CAT control problem. Hard to help without knowing your setup and your settings.
  6. W4SOU
    Ic-7300 ill post a picture later today of settings
  7. W4SOU
    Wsjt settings
    Says usb codec on audio settings
  8. K3DCW
    Looks to me like you don't have the Serial Port configured correctly, or you have the wrong one installed. "USB" is not a valid Serial Port device ID on Mac. It should be something like /dev/cu.SLAB.USBtoUART....
  9. W4SOU
    how do you get wsjtx to display the usb driver from slab?
  10. K3DCW
    Not sure which version of macOS you're running, so some steps may or may not be necessary, but I presume that you didn't follow the instructions about installing the driver before connecting the rig. If that's the case, don't worry. I can't tell you how many people do the exact same thing.
    Disconnect the rig from the Macbook (remove the USB cable from the Mac completely, don't just turn off the rig).
    Reboot
    Download and Install the SILabs Driver (not needed with Big Sur) from https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip
    Reboot again
    Plug in the USB cable and power on the rig.
    Go to the Security Settings in System Preferences and make sure that the driver is authorized to run.
    Reboot one more time for good measure and to make sure that the driver starts up normally after reboots.
    Start WSJT-X and it should show up.
