For Sale Receiver E-430 Ascom
Discussion in 'Ham Radio Gear For Sale' started by 9A2US, Oct 13, 2017.
  1. 9A2US
    9A2US Ham Member QRZ Page
    Ascom receiver E-430 ( Swiss army ) , Digital frequency display, accuracy 100 Hz, frequency range 1,600 - 11,9999 MHz .
    In the receiver section E-430, you find the main power switch and the volume control in the middle below the signal strength meter.
    The speaker grille is located at the left, the switch for the internal speaker, the headphones jack and the antenna BNC socket left of the speaker.
    At the right, you find a red LED memory channel and frequency display and a display for the internal test results in the top row, below the numbered keys of the direct frequency entry keypad ant at the right the modes switch: A1 stands for morse code tranmissions, A3JO and A3JU for upper lower sideband SSB reception, F1 and F4 are frequency shift radioteletype and data transmission modes.
    Make sure that the internal speaker is activated, set the volume control to a medium setting, select the reception mode and enter a frequency. Press CL and key in the desired frequency; use the command S followed by a digit 0 - 9 to store the frequency in one of the ten memory channels of the E-430. Pressing the button K followed by the channel number will recall the frequency from the respective memory channel. FS will recall the frequency the transmitter is tuned to to the receivers frequency memory. Use the combination K followed by three times CL for an emergency erase of all frequency memory contents, the receiver will be locked unteil you turn it off an on again.
    You can also use the + or - keys to tune the set up or down. For this press +, the frequency step and + another time, every time You press + again, the receiver will be tuned up the same amount.
    Price 1700 $ + shipping.Info email : oluja91@gmail.com
  2. QRZ
    Important Rules
    Have you read our Swapmeet Safety Rules?
    This forum enforces a set of buying/selling safety rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
