Radio setup for SAR
Discussion in 'Ham Radio Discussions' started by KM4SPU, Nov 9, 2018.
  1. W0PV
    W0PV Ham Member QRZ Page
    I just realized, now that the telescoping tubing antenna has been (unfortunately) busted off, that creates an opportunity to try making a more robust alternative - a tape measure element.
    As shown in this previously posted blog (scroll down a half dozen posts) this fellow used pieces of flexible steel tape measure to make a more rugged backpack whip. At 5 bucks for a 1" wide tape, its worth a shot. Just scrape off the paint and tie-wrap it tightly to the remaining stub of the failed telescopic tube. Make it 18.2" long total. Add the trailing wire counterpoise. Voilla!
    WZ7U likes this.
  2. KU4X
    KU4X Premium Subscriber QRZ Page
    And hopefully it will not slice an ear off as it snaps around! :eek:
    Seriously, at first glance it does appear to be a viable solution.
    Regards,
    -Bruce
  3. WZ7U
    WZ7U Ham Member QRZ Page
    Encase it in heat shrink tubing.
    W0PV and KU4X like this.
  4. W0PV
    @KM4SPU, I just realized a mistake in my suggestion for using tape-measure material to replace the broken telescopic tube. The telescopic tube whip you have was probably designed as a longer then 1/4w antenna, more likely a 1/2 or 5/8w whip, therefore has a loading coil integrated into its base just above the connector.
    If so then you should cut the tape measure material to essentially replace the length of the telescopic tube when it was fully extended. Duh. My bad.
    That is considerably more than 18.2" I spec'ed if it was simply a 1/4w length. Hopefully then the replacement tape measure material would get you back to at least the same performance as the original telescope tube indicated it could give.
    However, it still would be worthwhile to add a trailing wire counterpoise as described. Or alternatively try to make a center fed half-wave dipole tape measure replacement. And to verify the xmit operation of anything with borrowed instrumentation.
    Good luck!
ad: Handhrnet-1
