ad: vanity
Radio Installation on Minivan
Discussion in 'Mobile Radio' started by KC1DFG, Apr 21, 2015.
ad: QSOToday-1
  1. KC1DFG
    KC1DFG Ham Member QRZ Page
    Hi all,
    I have tried with no luck to run power cords directly to the car battery. I have Ford Freestar 07 van and could not even find a small slot to pass the wires. Any advice how to run the power wires from driver's side directly to the car battery, please? thank you, Edy
  2. HB9FUH
    HB9FUH Ham Member QRZ Page
    Drill a new hole.
  3. KW4EK
    KW4EK Premium Subscriber QRZ Page
    +1 if you must to find a path, but remember to use a grommet so that the sheet metal does not cut into the wires.
    Often times you can find some room to pass through your wires alongside the existing wires, but if that is not possible then drill a new hole, insert a grommet, pass your wires through, then seal the opening and wires, if need be, with some silicone sealant to keep rain and moisture out.
  4. KC1DFG
    ..guess i'll just do that.appreciate the adv.thank you.cheers,
  5. KC1DFG
    Appreciate the adv..never thought of that.thanks.cheers,
  6. KB2FCV
    KB2FCV Ham Member QRZ Page
    I have always snuck them in with existing wires. There is usually room to get something through.
