QSO's on FT8
Discussion in 'General Technical Questions and Answers' started by KN6KKW, Mar 30, 2021.
Tags:
  1. KN6KKW
    KN6KKW Ham Member QRZ Page
    I have WSJT setup and everything seems to be working but I haven't been able to make any QSO's on 20/40/80m.
    There is tons of activity but regardless of how much I call CQ I never get a response.
    I'm new to digital modes and am unsure if this is normal or not...
    I'm on a 991a using wsjt-x
  2. KP4SX
    Are you receiving plenty of stations?
  3. N7VGO
    N7VGO Ham Member QRZ Page
    How are you setup? Do you have a SWR/Power meter on your Xmitter cable and is it showing power out?
    Val
    KN6KKW likes this.
  4. K8XG
    K8XG XML Subscriber QRZ Page
    What is your ALC running at? Should be low with medium power output on power meter. You adjust your sound card speaker output setting to make ALC low but as a decent 35-45 watts out; you do not run it at 100 watts or will burn things up over the long haul. You are hearing all the folks but no-one is hearing you. Are you sure your only seeing WSPR receiving stations and not those that actually heard you just like this chart? [OP said in another post WSPR was fine, not sure it was] Folks that hear you on this chart will have a Flag with the number of mins ago they heard you.... Note that is says they last time they heard you was 26 hours ago listed under the 20meter box at the top.. Something is not set right...or changed... upload_2021-3-29_21-55-16.png
  5. KM8V
    KM8V Premium Subscriber QRZ Page
    K8XG likes this.
  6. K8XG
    062 Data Mode = OTHERS
    064 OTHER DISP (SSB) = 1500 Hz
    065 OTHER SHIFT (SSB) = 1500 Hz
    066 DATA LCUT FRED = OFF
    068 DATA HCUT FREQ = OFF
    070 DATA IN SELECT = REAR
    072 DATA PORT SELECT = USB
    In addition to menu settings, you will want to set the following modes and functions. Press F button to get to the function items.
    MODE = DATA-USB
    METER = ALC and Switch Back to Power Out to check medium power if you do not have an outboard Watt Meter. Mine normally has the ALC about 4/5s the way to the red line when I get 38 watts out using the speaker audio control... with Power out set to 38 watts in the menu.
    WIDTH = 3000
    NAR/WIDE = W 3000
  7. KN6KKW
    I'm receiving sooo many stations and when i go to psk reporter or ham spot it shows that i have received a bunch but haven't transmitted anything.
  8. KN6KKW
    No i don't have one inline.. It is just my 991a > tuner > antenna.
  9. KN6KKW
    I'm embarrassed to say that I am not too comfortable or familiar with ALC. I have it on as my main meter on the display but it never seems to change.
    I assumed wspr was working because the wspr.net map shows my contacts (I thought). I'm sure i'm missing something pretty basic...but i haven't changed anything on my radio that i can remember and on wsjt it looks like everything is working ok, no errors or problems transmitting. I don't know.
  10. KN6KKW
    I have all of those settings correct and the computer switches into data-usb automatically. ALC is setup as my meter but ive never seen it move at all.
