QSO Edit - Frequency entry bug?
Discussion in 'QRZ Site Community Help Center' started by VE2ZAZ, Sep 23, 2025.
  1. VE2ZAZ
    VE2ZAZ Premium Subscriber QRZ Page
    Greetings,
    I have been trying to edit some 3cm band records that were originally uploaded to my log through an ADI file. These QSOs have the "3 cm" band already entered, but no frequency was uploaded. When I edit such QSO, and click on save, I get an error popup stating: "Please fill in all required fields" and a red box is drawn around the frequency entry field. From that point on, any valid frequency I type in, whether in the format "10368" or "10368.000" will still result in the same error popup and red box. The format and frequency appear to be accepted for that band because if I type an frequency outside of the 3cm band, the error popup will also warn me of an invalid frequency for the band.
    And I cannot find any other red box drawn anywhere else in the four edit tabs, so it looks like it is only a frequency issue that is reported.
    Note that if I leave the frequency field untouched and instead edit any other field, the error popup will still warn me 'Please fill in all required fields." and the red box will still show around the frequency entry field, regardless of what I do.
    In summary, it is impossible to edit such QSO that has an empty frequency field, regardless of what I want to edit, because it will always complain about the frequency field, and even if I fill in a valid frequency while editing the QSO.
    Anybody knows if I am doing something wrong? To me it looks like a bug.
    Thanks in advance, 73
    Bert, VE2ZAZ - VA2IW
  2. K2EJT
    K2EJT XML Subscriber QRZ Page
    I have the same problem, and haven't been able to find a fix either.
  3. VE2ZAZ
    Thanks.
    There does not seem to be any support for bugs, even despite being a paying member... not even an acknowledgement. Disappointing.
  4. N1KB
    N1KB Premium Subscriber QRZ Page
    Having the same problem
  5. W4DPE
    W4DPE Platinum Subscriber Platinum Subscriber QRZ Page
    First heck the box for Log Split, then uncheck it and you can then save the change.
