*** QRZ Logbook Handbook ***
Discussion in 'Logbook User Forum' started by N0AMT, Dec 17, 2014.
  1. W1DQ
    It is in the works, up in 24 hours.
  2. LU4ERR
    LU4ERR Ham Member QRZ Page
    Hola,como puedo recuperas los contactos de mi logbook de qrz,nose que toque que borre todos,gracias,Tomas.
  3. W1DQ
    Debe importar el archivo de copia de seguridad de ADIF.
    Abra su libro de registro.
    Haga clic en SETTINGS then IMPORT
  4. N2UHC
    N2UHC Ham Member QRZ Page
    Quick question... what does it mean when some of your log entries are shaded green?
  5. UX3UU
    UX3UU Ham Member QRZ Page
    Gentelmen, after my transfer to new version all logbook is broken: logbook was stoppt to the date of middle of 2015, no incoming alerts, and a lot of error when itry to upload adif. Who know how to move back to old version? Mny tks
  6. W1DQ
    You need to adjust the date range of your logbook as its current end date is in 2015.
    Open your logbook
    Click on SETTINGS then PROPERTIES
    Adjust Start Date to date of first QSO.
    Adjust End Date to a future date such as the expiration date of your license.
    Save.
    Re-upload QSOs.
    UX3UU likes this.
  7. LU4ERR
    Hola,alguien sabe si se pueden recuperar los contactos de mi logbook d qrz.com que borre todo x error,gracias Tomas.
  8. W1DQ
    Desafortunadamente, una vez eliminados, los registros QSO no pueden ser recuperados. Debe exportar periódicamente su cuaderno de bitácora y almacenarlo como copia de seguridad; ese archivo sería entonces importado para devolverlo.
    La función de exportación se activa para aquellos que tienen una suscripción en el nivel XML o superior.
    Unfortunately, once deleted, the QSO records cannot be retrieved. You should periodically export your logbook and store that file as backup; that file would then be imported to return.
    The export feature is activated for those having a subscription at the XML level or higher.
    LU4ERR likes this.
  9. UX3UU
    But ok, i will send copy of my license
    many thanks, but i cant save changes: upload_2017-10-2_12-39-44.png
  10. W1DQ
