Proper method for calculating the resonant load resistor
Discussion in 'Amateur Radio Amplifiers' started by KB1SEL, May 15, 2011.
  1. KB1SEL
    KB1SEL Ham Member QRZ Page
    Hello all, Is it true in order to figure out the rl resistor value that you must take 1.8 and multiply it by the max plate current and then divide that awnser into the dc plate voltage rating. And that will give you the value of the non inductive resistor to be used.
    So basicly 1.8 x 1 amp = 1.8 4000 vdc / 1.8 = 2222.22
    So the rl resistor would be 2222.22 or the closest avaliable value non inductive resistor.
    Or does the other method work better plate voltage divided by max plate current to get the rl resistor value
    Does this sound right. Thanks
  2. K9FV
    K9FV Ham Member QRZ Page
    A good discussion of that very question took place here: http://forums.qrz.com/showthread.php?296719-PI-Net-question
    read thru the total thread, and Tom (W8JI) sums it up nicely in the last couple of posts on last page - I think that thread will clear up some of your questions..... and raise more:)
    73 de Ken H>
  3. KB1SEL
    Thanks. I think im all set though
  4. KB1SEL
    Tank coil installed and is set to perfect resonance. Thank you
