Programming a repeater into a wouxon kg-uv920p
Discussion in 'General Technical Questions and Answers' started by KC1EFD, Jun 12, 2019.
  1. KC1EFD
    KC1EFD Ham Member QRZ Page
    I own a wouxon kg-uv920p Mobile radio and I am trying to program a repeater into it with out software assistance. If anyone has programmed a repeater into this radio before using the radio and not software and could walk me threw it I’d be grateful for the help.
  2. KE0TNL
    KE0TNL Ham Member QRZ Page
  3. KC1EFD
    I’ve read it main times don’t understand it.
  4. KE0TNL
    Do you have the freq, offset, and PL tone for the repeater you're trying to use?
  5. KC1EFD
    Yes, but the manual is not clear about how to add the tone up/down into the radio.
  6. KA9JLM
    It looks like
    Menu 28 is transmitting CTCSS
    Menu 4 is Offset
  7. KC1EFD
    downlink 145.45000 (is this what i should be transmitting on?)
    uplink 144.8500 (is this what i should be receiving on?)
    offset -0.6 MHz (this I know how to do)
    unlink tone 100.0 (is this what the CTCSS is??)
    downlink tone 100.0
  8. ND5Y
    ND5Y Ham Member QRZ Page
    Downlink = repeater output (your receive frequency)
    Uplink = repeater input (your transmit frequency)
    Tone is the same as CTCSS. You only need this on your transmit frequency.
    You don't need a CTCSS tone on your receive frequency. Using tone squelch on recieve prevents you from hearing any signal that doesn't have the correct tone. This will cause problems if you don't know exactly what you are doing.
  9. KC1EFD
    ok thanks everyone for your help i just got the repeater to talk to me. finally a week of pulling my hair out.
