ad: Schulman-1
Problem uploading ADI file
Discussion in 'Logbook User Forum' started by IZ0IBA, Sep 14, 2019.
  1. IZ0IBA
    IZ0IBA Premium Subscriber QRZ Page
    I received an error while uploading a wjstx adi log file.
    There is a message coming out that say i was uploading a zero lenght file.
    This is not the case, the file is 9kb and was uploaded to eqsl.cc website as well without problem.
    Maybe there is something wrong with the import procedure. Everything was normal few days ago....
    73, Fabio
  2. W1DQ
    Open your QRZ logbook
    Click on SETTINGS then scroll to Import/Export History and View Reports
    There is no record of a failed import
    Try to load the ADI file directly: Click on Import
  3. VE3CGA
    John W1DQ, I think he's getting the same error I am. Mine was straight from my winlog32 logbook.
    tried it again with just 1 contact and still getting a zero file length report.
    The qso will download from LOTW into the qrz logbook
    beginning to sound like something common...
    Bob VE3CGA
  4. IZ4AIF
    IZ4AIF Premium Subscriber QRZ Page
    errore 228 sino a questa mattina funzionava?
  5. TA4AEI
    TA4AEI Premium Subscriber QRZ Page
    Same error here too.
  6. WA2NDV
    WA2NDV Ham Member QRZ Page
    Same here. Opened a ticket. Says file is zero length.
  7. W2ZF
    W2ZF XML Subscriber QRZ Page
    Its not working here. Can't import log. I click on import; it appears as if it wants to and just stops. Also can't upload to LOTW.
  8. IZ0IBA
    Update .... this morning, same file loaded ok ... sure there is some bug underneth the import procedure on the website that need to be investigated
    I did not change anything in the file simply reloaded it at 8:10 GMT.
    However, tnx for support.
    73, Fabio.
  9. AG5ND
    AG5ND Premium Subscriber QRZ Page
    It's working this morning.
    To whoever fixed it, thank you very much!
  10. W2ZF
    Working here now, as well. Thx.
