Problem exporting to LOTW
Discussion in 'Community Help Center' started by K6RWM, Jul 10, 2018.
  1. K6RWM
    K6RWM Premium Subscriber QRZ Page
    For some reason, I can no longer post up my logs to LOTW. Did I miss a change or something. It was fine a week or so ago. Here is the error message:
    Error occured while signing log records.0 records successfully sent to LoTW.
    Thanks -- 73.
    Bob - K6RWM
  2. W7UUU
    W7UUU QRZ Lifetime Member #133 Volunteer Moderator Life Member Platinum Subscriber QRZ Page
    Are you uploading from the actual computer that has your TQSL software and certificate loaded on it?
    The error you list means that TQSL could not "sign" your file. It must be done from the computer that has TQSL and your current, valid TQSL Certificate loaded on it.
    Dave
    W7UUU
  3. K6RWM
    Thanks, Dave. I have QRZ on my Mac, and have successfully exported to LOTW for years.
    I have my TQSL on my Windoze computer, which is the radio computer. So, I will try it there, as I have QRZ there as well. I just updated to the latest TQSL version last night.
    Okay, so tried it on the other computer, and same error message.
    Bob
    K6RWM
  4. K6RWM
    Okay, I worked the problem out.
    I went to the LOTW settings and reloaded my TQSL certificate. I can now export my QRZ contacts successfully to LOTW.
    Same certificate as I had previously, so apparently a glitch somewhere.
    Bob
    K6RWM
ad: wmr-1
