For Sale Pro-528 Scanner $70 Shipped
Discussion in 'Ham Radio Gear For Sale' started by KG4SZS, Jan 4, 2019.
  1. KG4SZS
    KG4SZS Ham Member QRZ Page
    The Pro-528 was manufactured by Uniden for Radio Shack.
    Frequency Range (MHz), Step (kHz)
    29 - 54 5
    108 - 136.9875 12.5
    137 - 174 5
    216 - 224.9950 5
    400 - 512 6.25
    806 - 956 12.5
    1240 - 1300 12.5
    Features
    4 different channel plans can be selected in Motorola trunking menu - not documented in manual
    1,000 Channels in 10 banks
    Multi-mode trunking (VHF, UHF, 800, 900, Motorola I/II/IIi, EDACS, LTR)
    Motorola Control Channel Only scanning option in menu with selectable plan for 800/900 mHz systems but only one site or system can be programmed per bank
    Scan rate 90cps
    Signal stalker I (with 10 autostore channels)
    Triple-Conversion Circuitry
    10 ID lists, 10 IDs, 100 per bank; 1000 IDs total
    Weather Search
    Weather Alert Indicator
    SAME-FIP Digital Weather Alert
    1 programmable Skywarn channel
    Two Second Scan Delay
    ID Delay
    EDACS Partial Talkgroups
    Lock Out Function
    200 Search Lockouts
    10 Priority Channels
    10 Priority IDs per bank
    Auto Backlight (light turns on when a signal is received)
    Four Service Banks - Police, Aircraft, Ham, and Marine
    Hypersearch/scan
    10 search banks
    Direct Search
    Key Lock
    Data Signal Skip (skips no-modulated or data signals)
    Motorola Disconnect Tone Detect (scanner tunes into data trunk channel when it receives a disconnect transmision)
    Status Bits
    Manual Access
    Liquid Crystal Display
    Display Backlight
    Key Backlight
    BNC Antenna connector
    Memory Backup
    Programming from PC/MAC (not controllable)
    Key tones (for correct entry or different tones for errors)
    Battery Save ( a mode to preserve power if no signal appears for 5 seconds)
    4 AA alkaline/Ni-MH batteries
    Absolutely NO Corrosion in/on
    box
    $70 Shipped top lower 48
    Pro-528 Scanner 1-4-2019.jpg battery
  2. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
