President Lincoln 2 plus Clarifier (RIT)
Discussion in 'General Technical Questions and Answers' started by KX2U, Jul 31, 2019.
  1. KX2U
    KX2U Ham Member QRZ Page
    I just realized that my clarafier knob does nothing when I use it to tune a USB or LSB station in. I have to tune it 1khz to hear the person properly and then I am off on transmit. Anyone know if the feature has to be enabled or should work out of the box?
  2. WA2CWA
    WA2CWA Ham Member QRZ Page
  3. WA4ILH
    WA4ILH Subscriber QRZ Page
    I thought (most) clarifier controls only worked on receive.
    Tom WA4ILH
    KA0HCP likes this.
  4. WZ7U
    WZ7U Ham Member QRZ Page
    "Clearly" that should be the case. :p
  5. KX2U
    It was tyhe CLARSET feature. choices are r,t or both. Pretty cool that you can lock the r and t without a mod.....
  6. W6MK
    W6MK Ham Member QRZ Page
    It's a CB radio. Don't know if at present it remains an illegal import for CB use.
    At any rate a very poor performer for ham use. Properly-implemented RIT and XIT functions are standard on ham gear.
    Not much is "cool" about that radio.
  7. KA9JLM
    A Slider works on transmit also. :rolleyes:
  8. K8JD
    K8JD Ham Member QRZ Page
    I have a Rad Shack HTX10 with a "clarifier" marked "fine tune" and it tuned both the T and R together, not just R!
  9. KX2U
    Not much cool about your response. No, its not a CB radio. You are sorely misinformed.....
    thanks for your less than decent response, If you don't like the radio than keep it to yourself since you didn't need to reply just to make a negative statement.
    KF7OXO, N7UJU and N8VIL like this.
  10. N5AF
    N5AF Premium Subscriber QRZ Page
