preamp component smoked - RF Concepts 2-417
Discussion in 'Amateur Radio Amplifiers' started by KD2QED, Nov 17, 2019.
  1. KD2QED
    KD2QED XML Subscriber QRZ Page
    Hi,
    I purchased a RF Concepts 2-417 and learned RF sensing is suboptimal for keying detection. This resulted in the preamp no longer functioning.
    I opened it up and have identified one of the components in here that looks burnt up, but I can't tell what it is. I've attached a picture of it.
    I have the schematic, but I'm having some trouble understanding it.
    Manual - http://www.radiomanual.info/schemi/ACC_PA/RF_Concepts_RFC-2-315_RFC-2-417_RFC-3-312_user.pdf
    Schematic - http://www.radiomanual.info/schemi/ACC_PA/RF_Concepts_RFC-2-315_RFC-2-417_sch.pdf
    I measured it at 3 ohms and the diode test returned 0.003 V.
    Can someone give me some advise on what this is and where it is in the schematic?
    I'm hoping it's simply a matter of replacing it to get it back running.
    Thanks,
    Jason
    KD2QED
    Full album: https://photos.app.goo.gl/Sn2LdLrhTTYsKqed6
  2. AA7QQ
    AA7QQ Ham Member QRZ Page
    A more vertical pic would be better. It might show where the traces go. Also, an underside pic with the lands identified would help.
    Ed
  3. KA0HCP
  4. WR2E
    WR2E Ham Member QRZ Page
    Looks like what's left of a metal film resistor.
  5. KD2QED
    Hi Ed,
    Thanks for the quick reply. Let me know if these are what you're looking for. I added some more to the album too.
    It's a challenging area to photograph. I will see what it takes to get this board off of the chassis to post the underside.
  6. K7TRF
    I'd guess that's either a small form factor molded inductor or one of the preamp protection diodes D13, D14.(it looks more like a small inductor to me, but the protection diodes might be more likely to actually blow). Really hard to say based on what the manual and schematic shows. I'd use careful visual inspection and an ohm meter to follow the traces on either side of that burnt component to see where they go. That should help you pin down where it is in the schematic.
  7. WR2E
    The metal end caps are typical of the construction of metal film resistors. I've seen them burnt up and that's what they look like. I can't say I've seen diodes or molded inductors that are burnt to a crisp like that.
    On the other hand, if it was a resistor, it would likely be OPEN and not read 3 ohms.
    So yeah, a diode might make more sense, they tend to fail shorted.
    But an inductor IS a DC short.
  8. WR2E
  9. K7TRF
    I was thinking molded inductors like these that have a similar construction. But yes, a resistor probably fits what we can see better though I'd expect most resistors to burn up in open circuit mode and not show 3 ohms as the OP posted (though I guess most inductors would burn up in open circuit mode as well :) )
    Either way unless someone else has one of these and can verify what that part is, the best bet is to trace the circuit to figure out where the mystery device connects.
    WR2E likes this.
  10. WR2E
    I think you're right...
