Power supply for RV operation
Discussion in 'On the Road' started by K7GDR, Jun 30, 2021.
  1. KI4ZUQ
    KI4ZUQ Ham Member QRZ Page
    I have been using a 55 amp RV converter as a DC power supply for several years now if that was part of your original question. It is very quiet and more than capable. It would be better to "float" a battery or two across its output for filtering but really is unnecessary it is so "quiet."
    Also have been using a 30 converter from Amazon ($20.00 USD) that is just as quiet.
    K0UO likes this.
  2. K6EEN
    K6EEN Ham Member QRZ Page
    Depends. If you're camping with access to power, i.e. campground 110V service, then no. You can just run a regular ham power supply off the 110V outlets in the camper. Or if your camper has a 110V gas generator, you can run the generator and use the 110V service. If you want to "boondock" and run the camper off of batteries/solar, then a 12V line from the camper's battery to the operating position can help. Use large gauge wire for long 12V runs --- lots of voltage drop for long runs at 12 volts.
  3. K0UO
    Some of those are actually pretty good you find a quiet brand they make great power supplies
    KG4RRH and KI4ZUQ like this.
