Power socket
Discussion in 'General Technical Questions and Answers' started by GW4ROV, Sep 11, 2019.
  1. GW4ROV
    GW4ROV Ham Member QRZ Page
    Hi all does any one know the cables that go to the power socket on a ICOM ic-271e . The obvious being red and black the red to the right then black then red and below that there's another pin that I would think should be black ? but is a orange one . And i need to make a plug to power it up many thanks Phillip GW4ROV
  2. AE5C
    AE5C Ham Member QRZ Page
  3. GW4ROV
    AE5C Thanks for the reply much appreciated Phillip GW4ROV
  4. WA9SVD
    WA9SVD Ham Member QRZ Page
    Just a guest, but the "orunj" wire may be for connection to the memory, and keep power (@ a very low current draw) even when the auto power is "OFF ." Red is usually Positive, Black Negative @12-13.8 Volts. Check the manual to be SURE, but if you are using the radio in a fixed station, the two can be tied together; or in most cases, just ignored. But follow the wiring in the owner's manual to be SURE. YMMV.
  5. GW4ROV
    Many thanks Larry
