Power for FT8
Discussion in 'Working Different Modes' started by HB9DDS, May 22, 2021.
Tags:
Output Power FT8
Poll closed Jun 21, 2021.
  1. 1W
    1.5%
  2. 1-10W
    10.4%
  3. 10-25W
    14.9%
  4. 25-50W
    32.8%
  5. 50-100W
    22.4%
  6. 100W and more
    17.9%
  1. HB9DDS
    HB9DDS XML Subscriber QRZ Page
    I would be interested to know what power FT8 (watts) you working with.
  2. PA5COR
    PA5COR Ham Member QRZ Page
    Anywhere between 50 to 100 watts or what is neeeded to make the qso's work, never over 100 watts though.
    W4KJG likes this.
  3. W3TKB
    W3TKB XML Subscriber QRZ Page
    I generally set my radio TX to 40w for the various digital modes, but sometimes I'll boost upwards to 80w or 90w while trying to establish a contact, especially on FT8.
  4. K1VSK
    K1VSK Ham Member QRZ Page
    Seldom bother with FT8 but have never needed more than 10w
  5. WA9FZB
    WA9FZB XML Subscriber QRZ Page
    There are so many variables in making a QSO, regardless of mode.
    I usually run 40-50 watts, but have been known to crank it all the way to my max of 100 watts to try to make a QSO. It only makes 3 dB difference, but maybe it will make a difference.
    I'm running a Kenwood TS-590SG, which Kenwood rates at 100 watts RTTY/Digital. If I did run 100 watts continuously, the fans would be on most of the time.
    W4LJ likes this.
  6. KD9VV
    KD9VV Ham Member QRZ Page
    Interesting question.
    Really depends on the freq too IMO.
    6M lately is open with Es season upon us.
    That said, 6M stations with amplifiers are using them..500W-1000W
  7. HB9DDS
    Personally, I think the appeal of digital modes is being able to do a lot with very little power.
    My equipment is:
    - Kenwood TS-2000
    - Output power mostly on all bands 10W (maximum 50W)
    - Antenna DIY Vertical 7M
  8. HB9DDS
    This is really nonsensical and I do not approve of it.
  9. K3XR
    K3XR Ham Member QRZ Page
    My guess is that those who respond are not seeking approval.
    It's been touched upon but there are variable factors that come into play when deciding on power levels. It's a bit more complicated than the following statement but it about covers it..."the minimum transmitter power necessary to carry out the desired communications."
    N3RYB, N4UP and WG7X like this.
  10. W4HWD
    W4HWD Premium Subscriber QRZ Page
    The minimum power necessary to make the contact.
    Sometimes it's 5w, sometimes it's 500w.
    Better antennas mean less power needed. My antennas are ok at best, so sometimes less sometimes more, just depends on the band, the competition, the distance and how bad I want to work that station. Sometimes 500w won't get it done so I take a pass as that's all I got. Depends.
    N3RYB, AJ4WC, N4UP and 2 others like this.
