Perfect Paint Matching
Discussion in '"Boat Anchor" & Classic Equipment' started by KI7WQH, May 18, 2018.
  1. KG7HVR
    KG7HVR Ham Member QRZ Page
    Those look very good. Where is he getting the paint made?
    Speaking of kenwood! Has anyone matched the dreaded trim rub off on a ts570 or ts450sat? Seems they all rub off leaving black plastic underneath.
  2. VK6APZ
    VK6APZ Premium Subscriber QRZ Page
    He gets the paint from a local paint store in Perth that will make up any color you want.
  3. K9STH
    If you keep the paint can tightly sealed, the paint can last for a number of years.
    As for getting spray cans loaded: Most paint stores in this country do not have the ability to load spray cans. In metropolitan areas, the paint companies usually have a warehouse operation where the cans can be loaded. In the Dallas, Texas, area, Sherwin-Williams has such an operation that is about 10-miles from my house. However, unless the paint just happens to be a color that is used by several regular customers, you have to pay for a quart of the paint and then pay additional to get it loaded into the spray cans.
    Typically, if one has a spray rig, it is MUCH easier to get a good paint job on the unit. With practice, it is possible to get a good paint job but, unfortunately, the majority of people have problems. There are times when I do use a spray can (off the shelf that is a good match, for a "one off" unit, etc.). However, I prefer to do the job with an air compressor and paint gun.
  4. KK4NSF
    KK4NSF Ham Member QRZ Page
    You are right... but you can get a Preval Spayer, which allows you to use regular paint in a spray-can type set up. [​IMG]
    You just pour the paint into the jar, and spray. I restore antique bicycles, and have no problem getting a perfect color match, and a smooth finish using them. Best of all, they are cheap..... like $10 or so for two of them. They are really handy, and spray just like a spray can.
    You can get 'em at Home Depot, Walmart, on Amazon, and at many paint stores. Here are some links:
    https://www.walmart.com/search/?que...1032966938&wl5=9012990&wl6=&wl7=&wl8=&veh=sem
    https://preval.com/
    http://acehardwaremaldives.com/product/paint/17738/
    https://www.homedepot.com/p/Preval-9-oz-Complete-Spray-Gun-267/202533738
    W1TRY likes this.
  5. KJ7MX
    KJ7MX Ham Member QRZ Page
    These might come in handy for a couple Collins cabinets I need to refinish. I read some of the reviews on the Home Depot website and there are a lot of negative reviews that look like they're due to the paint not being properly thinned. What has your experience been with proper thinning?
  6. K9STH
    MX:
    If you need the Sherwin-Williams paint formulas, which can be duplicated by any GOOD paint store (NOT home improvement centers), they can be found at:
    https://img1.wsimg.com/blobby/go/11...ds/Boat_Anchor_Paints-1.pdf?ver=1570751570182
    Note that the Collins S-Line cabinet formula is for 1-gallon. However, the paint store can reduce it for just 1-quart. The remainder of the formulas, in the article, are for 1-quart which is the smallest portion that most paint stores will custom make.
  7. KK4NSF
    the rule for thinning with these sprayers is this: If you don't thin the paint, it doesn't spray. I tend to thin it by eye to about the viscosity of water. I only takes a tiny bit of thinner in the little jar, and you are good to go.
  8. KM1H
    KM1H Ham Member QRZ Page
    My well used TS-950SD has the black exposed also; driven hard and put away wet in decades of heavy contesting and DXing.
    Carl
  9. KB3MOW
    KB3MOW Ham Member QRZ Page
    When the gas tank on my old motorcycle got scratched up I found an auto parts distributor who matched the original color perfectly, and even provided the paint in a spray can. Yes, it was a bit expensive - $90 for one can. It cost me more in GAS to find the one parts store that custom-matched paint! However, with that one can of paint I was able to apply three coats to the gas tank, along with 3 coats of clear-coat. Looked even better than the original and the tank matched the bike color perfectly! Sometimes the extra cost is actually worth it!!
    73 es GL
    Dave - KB3MOW
