SOLD OREN-ELLIOTT big air variable capacitors (last pair)
Discussion in 'Ham Radio Gear For Sale' started by W5MP, Dec 30, 2018.
  1. W5MP
    W5MP Ham Member QRZ Page
    I have a last pair of identical Oren-Elliot air variable capacitors for sale. Each is 200 picofarads at 4kv spacing. Between any stator and rotor is 1/8th inch spacing. Each cap has a PAIR of 10 amp rotating contacts at each end. These are of recent manufacture, 2014, not some crusty old stock. I used four of these fine air var. caps in one of my two big antenna tuners. Sell each for $75 and I pay for the shipping via U.S. Priority Mail. Seen in the photos and included are three 68 pf door-knob capacitors in parallel, totaling about 205pf. This assembly of door-knob caps are easily removable, if desired. Each air var. caps has a pair of big Delrin stand-off insulators, should you need to mount the cap above your chassis, as I did. If not needed and the rotor needs to be grounded, the Delrin insulators are easily removable. Will package well for safe arrival at your QTH. I pay for shipping. Sell each or as a pair. The big air var. caps are connected together with a Delrin coupler, but you can easily separate them. E-mail or call anytime. (713) 502-2450 Mike W5MP
  2. KB0EL
    KB0EL XML Subscriber QRZ Page
    Markings in photo 102 seem to indicate the air-variable only is only 97-181 pf. The three paralleled 63s seem to be in series with the rotor. What is the pf range of just the air-variable portion?
  3. W5MP
    SOLD-- I have a last pair of identical Oren-Elliot air variable capacitors for sale. Each is 200 picofarads at 4kv spacing. Between any stator and rotor is 1/8th inch spacing. Each cap has a PAIR of 10 amp rotating contacts at each end. These are of recent manufacture, 2014, not some crusty old stock. I used four of these fine air var. caps in one of my two big antenna tuners. Sell each for $75 and I pay for the shipping via U.S. Priority Mail. Seen in the photos and included are three 68 pf door-knob capacitors in parallel, totaling about 205pf. This assembly of door-knob caps are easily removable, if desired. Each air var. caps has a pair of big Delrin stand-off insulators, should you need to mount the cap above your chassis, as I did. If not needed and the rotor needs to be grounded, the Delrin insulators are easily removable. Will package well for safe arrival at your QTH. I pay for shipping. Sell each or as a pair. The big air var. caps are connected together with a Delrin coupler, but you can easily separate them. E-mail or call anytime. (713) 502-2450 Mike W5MP SOLD--
  4. QRZ
    Important Rules
    Have you read the Swapmeet Rules?
    This forum enforces a set of buying/selling rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Got questons? Contact our moderation team here...
    All Sellers Must Be Verified As of July 1, 2019, only Verified Users are permitted to post in this forum.
ad: M2Ant-1
