Ohio/Penn DX Bulletin #1339
Discussion in 'Contests, DXpeditions and Special Events' started by KB8NW, Nov 12, 2017.
  1. KB8NW
    KB8NW Ham Member QRZ Page
    SB DX @ WW < KB8NW $OPDX.1339
    Ohio/Penn DX Bulletin No. 1339
    The Ohio/Penn DX PacketCluster
    BID: $OPDX.1339
    November 13, 2017
    Editor Tedd Mirgliotta, KB8NW
    Provided by BARF80.ORG (Cleveland, Ohio)
    Written/Sent from Strongsville, Ohio
    Thanks to the Northern Ohio Amateur Radio Society, Northern Ohio DX
    Association, Ohio/Penn PacketCluster Network, AB5K & the AR TelNet Clusters
    Network, NJ1Q & W1AW, NG3K & ADXO, W3UR & The Daily DX, W6NV, W6SZN, K8GI,
    K8YSE, W8GEX & 60m DX News, WD8IOU, DL1SBF, DL7BC, DL7UXG & The DX News
    Letter, DxCoffee.com, DXNews.com, DX-World.Net, ES1CW, F6AJA & Les Nouvelles
    DX, I1JQJ/IK1ADH & 425 DX News, I2MQP & DX Italia News, ON5SWA, OZ6OM & 50
    MHz DX News, Radio Club Argentino (LU4AA), RSGB IOTA Web Site, Sixitalia
    Weekly, VA3RJ & ICPO, VHF-DX-Portal (MMMonVHF) and YO3JW for the following
    DX information.
    DXCC COUNTRY/ENTITY REPORT: According to the AR-Cluster Network for the
    week of Sunday, 5th/November, through Sunday, 12th/November there were 224
    countries active. Countries available: 3A, 3B8, 3B9, 3C, 3D2, 3DA, 3V, 3W,
    3X, 4J, 4L, 4O, 4S, 4U1I, 4W, 4X, 5A, 5B, 5H, 5R, 5T, 5U, 5V, 5W, 5Z, 6W,
    6Y, 7Q, 7X, 8P, 9A, 9G, 9H, 9J, 9K, 9L, 9M2, 9M6, 9N, 9Q, 9U, 9V, 9X, 9Y,
    A3, A4, A5, A6, A7, A9, AP, BV, BY, C2, C3, C9, CE, CE0Y, CE9, CM, CN, CP,
    CT, CT3, CU, CX, D2, DL, DU, E5/n, E5/s, E7, EA, EA6, EA8, EA9, EI, EK,
    EL, EP, ER, ES, ET, EU, EX, EY, F, FG, FH, FK, FM, FO, FP, FR, FS, FY, G,
    GD, GI, GJ, GM, GU, GW, H4, HA, HB, HB0, HC, HH, HI, HK, HK0/a, HL, HP,
    HR, HS, HZ, I, IS, J6, J8, JA, JD/o, JT, JW, K, KH0, KH2, KH6, KL, KP2,
    KP4, LA, LU, LX, LY, LZ, OA, OD, OE, OH, OH0, OK, OM, ON, OX, OY, OZ, P2,
    P4, PA, PJ4, PJ5, PY, PZ, S0, S5, SM, SP, ST, SU, SV, SV5, SV9, T2, T7,
    TA, TF, TG, TI, TJ, TK, TR, TT, TY, TZ, UA, UA2, UA9, UK, UN, UR, V3, V4,
    V5, V6, V7, V8, VE, VK, VK9C, VK9L, VK9M, VK9N, VK9X, VP2E, VP2M, VP8,
    VP8/h, VP9, VQ9, VR, VU, XE, XU, YA, YB, YI, YJ, YK, YL, YN, YO, YU, YV,
    Z2, Z3, ZA, ZB, ZD7, ZF, ZL, ZP, ZS
    * PLEASE NOTE: The report "could" contain "Pirate/SLIM" operations or
    more likely a "BUSTED CALLSIGN". As always, you never know - "Work
    First Worry Later".
    3C1, EQUATORIAL GUINEA (Update). By the time you read this, operators
    Yuris/YL2GM and Kaspars/YL3AIW should be QRT as 3C1L from Luba located
    on the ocean's coast. ClubLog.org shows as of 0315z, November 9th, the
    3C1L team made 35143 QSOs with 12481 unique callsigns (28307/CW, 1532/RTTY
    and 5304/SSB). Breakdown is: 246/AF, 3708/AS, 22191/EU, 8118/NA, 78/OC
    and 802/SA. QSL via YL2GN direct or ClubLog's OQRS (direct or Bureau).
    Look for the logs to be uploaded to LoTW six months after their operations.
    Updates are being posted to: http://www.lral.lv/3c0l_3c1l
    LAST MINUTE UPDATE (November 12th): Operation is over. 3C1L is QRT since
    November 12 05:00 GMT. Around 42,000 QSOs made it into 3C1L log during
    roughly 16 days of on-the-air time. Plus 32,447 QSOs in 3C0L log in 12
    days on the air. Yuris will upload the last part of 3C1L log today in
    the evening when in Malabo. Their flight home is on November 13 morning.
    3D2/R, ROTUMA ISLAND (Update). Operators Tony/3D2AG, Heye/DJ9RR, Erno/
    DK2AMM, Hans/DL6JGN and Ronald/PA3EWP will be active as 3D2EU from Rotuma
    Island (OC-060) between February 23rd and March 16th, 2018. They will have
    two radio locations on the western peninsula of Rotuma. One in Fapufa in
    the south. This is the annual QTH of Tony. The second QTH is in Maftoa on
    the north coast. This is a joint operation using the resources of Tony and
    the European group. Activity will be on 160-10 meters using CW, SSB and
    the Digital modes. The team will use two stations (2x K3, 1x Expert 1,
    3k-FA and 1x Tokyo Hy-Power HL-1.1KFX), a Spiderbeam and vertical antennas.
    Subject to a reliable Internet connection, they will upload the log to
    ClubLog on a daily basis. Otherwise the complete log will be uploaded
    upon their return. QSL via DK2AMM (OQRS, direct, by the Bureau, LoTW).
    They now have a Web page online at: http://www.rotuma2018.de
    3V, TUNISIA. SWL Ashraf "Ash", 3V4-002 (KF5EYY), will be active as 3V8SS
    from the "Radio Club Station of Tunisian Scouts" in Sousse, during the
    CQWW DX CW Contest (November 25-26th) as a Single-Op/All-Band/Low-Power
    entry. QSL via LoTW or to LX1NO. Read about Ashraf on the following Web
    page at: http://www.kf5eyy.info
    5A, LIBYA. Abubaker, 5A1AL, has found the new FT8 mode to operate on the
    30 meter band. QSL via his home callsign. QRZ.com states, "Last log update
    into ClubLog was on November 8th, at 2330 UTC.
    5B, CYPRUS. Alex, SQ9UM, is now active as 5B/SQ9UM from Cyprus (AS-004)
    until November 17th. Activity will be holiday style on 40-6 meters,
    including 30/17/12m, using CW, RTTY, PSK and FT8. QSL via his home
    callsign.
    5N, NIGERIA. Bodo, DF8DX (ex-DL3OCH), will once again be active as 5N7Q
    from the Voice Of Nigeria in Abuja between November 12-16th. Activity
    will be limited to his spare time (there working) on 80-10 meters using
    mostly CW. QSL via DF8DX, LoTW or ClubLog's OQRS.
    6W, SENEGAL. Willy, ON4AVT, will be active as 6W/ON4AVT from Mbour some-
    time in February 2018. Activity will be on 20 meters using CW, SSB, PSK31
    and PSK63. Equipment is a Yaesu FT891 transceiver into a Buddipole antenna.
    9U, BURUNDI (Update). Members of the Mediterraneo DX Club are now active
    as 9U4M until November 17th. Activity is on 160-10 meters using CW, SSB,
    RTTY and FT8 (see OPDX.1338 for frequencies). ClubLog.org shows as of 1618z,
    November 12th, the 9U4M team made 32833 QSOs with 11773 unique callsigns
    (16016/CW, 13051/SSB, 3469/RTTY and 297/FT8). Breakdown is: 474/AF, 2847/AS,
    23359/EU, 5196/NA, 131/OC and 826/SA. QSL via IK2VUC, direct, by the Bureau,
    ClubLog's OQRS or LoTW. For more details and updates, see:
    http://www.mdxc.org/9u4m
    ARGENTINA NEWS (new bands/other bands get extended). The Radio Club
    Argentino (LU4AA), IARU Member Society, informs the international amateur
    community that they have succeeded with its petition to their local
    communications authorities, having granted new privileges to the Amateur
    Radio Service on 630m and 60m as well as getting extensions on existing
    allocations on 160m, 80m and 30m. The new allocations are the final
    result of efforts made by the RCA during its participation in the pre-
    paratory meetings of the WARC '07, '12 and '15; and will be effective
    in 90 days.
    New allocations Extended allocations
    630m -- 472–479 kHz 160m -- 1800–2000 kHz
    60m -- 5351.5–5366.5 kHz 80m -- 3500–4000 kHz
    30m -- 10100–10150 kHz
    AU2, INDIA (Special Event). Look for special event station AU2JCB to be
    active between November 23rd and December 11th. Activity will be on 40-10
    meters using SSB. Suggested frequencies are (depending on the propagation):
    3710, 7040, 7150, 14210, 14250, 14310, 21235, 21310, 21350, 28490, 28510
    and 28545 kHz. On FM Mode: 6m - 50800 and 51500; 10m 29700 kHz If higher
    bands are open, operations will be on those bands. The operator will be
    Surabhi, VU2DSI. QSL direct (with 2 IRCs) to VU2DSI. Operations are to
    celebrate the 159th anniversary of the birth (November 30th) of Sir
    Jagadeesh Chandra Bose, India's great scientist and inventor who they
    consider the "Father of Wireless Communication". For more details, see
    the following Web page at: http://www.qsl.net/vu2msy/JCBOSE.htm
    C2, NAURU (Reminder). Operators Kuni/JA8VE, Mat/JA1JQY and Kaoru/JA3MCA
    are now active as C21VE, C21JY and C21JY, respectively from Nauru (OC-031)
    until November 14th. Activity will be on 80-10 meters using CW, SSB and
    RTTY. QSL via their home callsigns, direct or by the Bureau.
    CR2/CU4/CT8, AZORES (Rare IOTA/Update). Operators Alan/K0AV and Oliver/W6NV
    will activate the rare IOTA Graciosa Island (EU-175) in the Azores Group
    between November 21-28th. Oliver, W6NV, will be active as CR2M during the
    CQWW DX CW Contest (November 25-26th), while Alan, K0AV, will be active
    as CU4DX during the contest. Look for Oliver to sign as CT8/W6NV on the
    lower bands prior to the contest. Look for Alan to be active as CT8/K0AV
    before the contest with possible SOTA activations and some 60 meters. QSL
    CT8/W6NV via W6NV direct. QSL CT8/K0AV via K0AV direct. QSL CR2M via LoTW.
    QSL CU4DX via LoTW.
    CR3, MADEIRA ISLAND. Jose, CT1BOH, will be active as CR3OO during the
    QCQWW DX CW Contest (November 25-26th) as a Single-Op/All-Band entry.
    QSL via LoTW.
    DXCC NEWS.................
    4W/OZ1AA -- It has been reported that Thomas, OZ1AA, states his 4W/OZ1AA
    log from East Timor has been uploaded to LoTW and "the
    operation has been approved for DXCC."
    FT5XT -- QSL Manager Stephane, F4DXW, reports "good news" as "all
    the proofs were sent to the ARRL by email and by mail (paper
    copy) to accredit the FT5XT activities and also FT5WQ."
    Sharon Taratula, Awards Manager, has told Stephane that
    both operations are now approved for DXCC credit. The
    FT5XT operation was from Kerguelen Island on October 11th.
    Gil has not yet been active this year as FT5WQ from Crozet.
    Also, LoTW certificate has been requested for both calls and
    Stephane says once received he'll upload the FT5XT logs.
    ED8, CANARY ISLANDS. An international contest team will be active as ED8X
    from La Palma Island (IOTA AF-004, DIE S-012, WLOTA 1276, EAA TF) during
    the CQWW DX CW Contest (November 25-26th) as a Multi-Single entry. Operators
    mentioned are Kresimir/9A5K, Emir/E77DX, Krassimir/K1LZ, Velimir/K3JO,
    Alexey/RA1A, Alexey/RN1AM, Vladimir/RW1A, Andrey/RW7K, Adi/S55M, Alexandru/
    YO8TTT, Ionut/YO9WF and Tiberiu/YO9GZU. QSL via LoTW or RN3RQ.
    FY/TO2, FRENCH GUIANA. Hartwig, DL7BC, will be active as FY/DL7BC/p from
    French Guiana in 2 weeks. He tells OPDX that he will leave for his first
    visit (reaching there on Saturday, November 25th), but first will have to
    set up an antenna of his friend Bruno, FY4VA (also DH1BL, ex-FY4VOS).
    Hartwig will go back to DL-land on December 7th in the afternoon, so he
    might close down the station on the 7th around noon time. His second visit
    will then take place around March 12-13th, 2018, and then he will return
    home probably on March 26th. He will be active as TO2BC during the BARTG
    HF RTTY (March 17-18th, 2018) and CQWW WPX SSB (March 24-25th) contests.
    Again, look for him to be active as FY/DL7BC/p before and after the
    contests. Activity will be on 40-10 meters (possibly 80m) using a Kenwood
    TS590SG into a Spiderbeam for 20-10m with WRTC-40m-extension and a Triple-
    Leg for 40m. QSL via his home callsign, direct, by the Bureau or LoTW.
    Watch his Web page for updates at: http://www.qslnet.de/dl7bc
    FY, FRENCH GUIANA. Operator Didier, FY5FY, will be active during the CQWW
    DX CW Contest (November 25-26th) as a Single-Op/Single-Band (20m)/Low-
    Power entry. QSL via FY5FY.
    GREEN PARTY AND WWFF ACTIVITIES.......
    VKFF-0622 -- By VK3TKK; November 13th; between 0300-0700z; French
    Island National Park; 7150 khz SSB; Try 80 & 40m
    VKFF-0744 -- By VK3XV/P; November 13th; between 0300-0700z; Cape Conran
    Coastal Park
    VKFF-0119 -- By VK2AWJ; November 13-14th; Croajingolong National Park;
    7144 kHz SSB
    VKFF-0618 -- By VK2AWJ; November 13-14th; Alfred National Park; 7144
    kHz SSB
    VKFF-0158 -- By VK3XV/P; November 13-14th; Morning Errinundra National
    Park; 7144 kHz SSB
    VKFF-0026 -- By VK5PAS/2 and VK5FMAZ/2; November 14th; between 0300-
    0700z; Ben Boyd National Park; 7144 kHz SSB
    VKFF-0455 -- By VK3XV/P; November 14th; between 0300-0700z; Snowy
    River National Park; 7144 kHz SSB
    VKFF-0761 -- By VK5PAS/3 and VK5FMAZ/3; November 14-15th; Lake Tyers
    State Park; 7144 kHz SSB
    VKFF-0321 -- By VK2AWJ; November 14-15th; Mitchell River National
    Park; 7144 kHz SSB
    VKFF-0962 -- By VK5PAS/3 and VK5FMAZ/3; November 15th; between 0300-
    0700z; Colquhoun Regional Park; 7144 kHz SSB
    VKFF-0556 -- By VK3ZPF/P; November 15th; between 0300-0700z; Yarra
    Ranges National Park; 7144 kHz SSB; Also 80/20/15/12/10m
    VKFF-0321 -- By VK3XV/P; November 15th; between 0300-0700z; Mitchell
    VKFF-0480 -- By VK5PAS/3 and VK5FMAZ/3; November 15-16th; Tarra-Bulga
    VKFF-0484 -- By VK2AWJ; November 15-16th; The Lakes National Park;
    7144 kHz SSB
    VKFF-0626 -- By VK5PAS/3 and VK5FMAZ/3; November 16th; between 0300-
    0700z; Morwell National Park; 7144 kHz SSB
    VKFF-0758 -- By VK3XV/P; November 16th; between 0300-0700z; Holey
    Plains State Park; 7144 kHz SSB
    VKFF-0020 -- By VK2AWJ; November 17-18th; Baw Baw National Park;
    7144 kHz SSB
    OHFF-0011 -- By OH6EFH/p; November 19th; OHFF-0019 Leivonmaki National
    Park; 80m SSB; Operator Kai, OH6EFH
    For more information about WWFF upcoming operations, see:
    http://wwff.co/agenda
    Also suggest URLs:
    World-Wide -- https://www.facebook.com/groups/WWFF44
    USA -- https://www.facebook.com/groups/parksontheair
    A special DXCluster for WWFF is available at: http://wwff.co/dx-cluster
    Canada Flora & Fauna (VEFF) link is:
    https://www.facebook.com/groups/Canadawwffveff
    Other links for VEFF are:
    Home Page at: http://www.qsl.net/va3rj/veff.html
    Yahoo Groups: https://groups.yahoo.com/group/veff
    PLEASE NOTE: Yahoo Groups might be removed if the Facebook Group works
    as expected. However, it will remain online well into the New Year 2018.
    HK0, SAN ANDRES AND PROVIDENCIA (Reminder). By the time you read this,
    members of the Yaguarete DXers Group will be active as 5K0T from San
    Andres Island (NA-033) until November 25th. Activity will be on 160-10
    meters using CW, SSB and various Digital modes. QSL via LU1FM.
    HP8, PANAMA. Operators Mike/W1USN and Bob/AA1M will once again be active
    as HP8/W1USN and HP8/AA1M, respectively, from Panama between February
    1-15th, 2018. Activity will be on various HF bands using CW, SSB and the
    Digital modes. QSL HP/W1USN via W1USN direct or LoTW. QSL HP/AA1M via
    AA1M direct or LoTW.
    HQ9, HONDURAS (Update). Operators Dennis/W1UE, Paul/K1XM and Charlotte/
    KQ1F will be active as HQ9X during the CQWW DX CW Contest (November
    25-26th) as a Multi-2 entry. They will be operating from Chillax Roatan
    (NA-057). QSL via KQ1F. Operators will be active outside of the contest
    signing homecall/HR9. W1UE will be there between November 11-27th, and
    K1XM/KQ1F will be there between November 18-27th.
    IOTA NEWS..............
    SA-040/
    SA-093. (Update/Postpone). Reports indicate that Martin, LU9EFO, has
    stated [edited], "Due to the strike of pilots of the Avianca
    Local Airline of Colombia, the team of the DXpeditions to IOTA
    SA-040 and SA-093 (operators Martin Butera/LU9EFO and Camilo
    Andres Fierros Castellanos/HK3TU), have decided to postpone
    their DXpedition until February of next year."
    PLEASE NOTE: Since the Webmasters of the new <www.iota-world.org> have
    decided NOT to post or dedicate a Web page to announced upcoming IOTA
    operations, PLEASE send your IOTA operations information to the OPDX
    and we will post it here in an upcoming bulletin......
    J5T GUINEA BISSAU DXPEDITION (Reminder). The Italian DXpedition Team will
    be active as J5T from Bubaque Island (AF-020) this week between November
    13-26th. They expect to have 4 stations on all HF bands (no 50 MHz), using
    CW and SSB, and RTTY one band only, to be chosen. It was also mentioned
    that there will not be any FT8 operations. You can participate in the J5T
    survey on their official Web site at: http://www.i2ysb.com/idt
    Subject to the availability of internet connection, the REAL TIME Log
    will be available at: http://win.i2ysb.com/logonline
    Official forum at: http://www.hamradioweb.net
    QSL via I2YSB direct, OQRS or LoTW.
    JW, SVALBARD. Erik, LA2US, will once again be active as JW2US from Bear
    Island (IOTA EU-027) for the next 6 months starting in early December.
    Activity will be limited to his spare time and he will operate on various
    HF Bands mostly CW at the lower band edges and IOTA frequencies. Also,
    on this trip he will be on BPSK, FT8 and RTTY. Equipment is a FT-450D,
    Signalink USB, Expert 1K-FA and a OCFD antenna. QSL via ClubLog's OQRS,
    LoTW or eQSL.
    PJ2, CURACAO. Before going to Aruba for the CQWWDXCW Contest, Alex, KU1CW,
    will be active as PJ2/KU1CW from Curacao (SA-099) between November 15-20th.
    Activity will be on various HF bands. QSL via LoTW.
    PROPAGATION FORECAST/REPORT (November 13-19th).......
    Nov/13th AN Nov/16th AN Nov/18th AN
    Nov/14th AN Nov/17th AN Nov/19th AN
    Nov/15th HN
    SOLAR REFERENCE KEYS/INDEXES AND GEOMAGNETIC REFERENCE
    NORMALITY GEOMAG K Values Alpha
    AN - Above Normal Quiet K=0-1 0-7
    HN - High Normal Unsettled K=2 8-15
    LN - Low Normal Active K=3 16-29
    BN - Below Normal Minor Storm K=4 30-49
    DIS - Disturbed Major Storm K=5 50-99
    VRY DIS - Very Disturbed Severe Storm K=6-9 100-400
    REALTIME BAND CONDITIONS WEB SITE <http://www.bandconditions.com>:
    The purpose of this experimental Web site is to provide 24-7-365 actual
    (REALTIME) band condition information to CW QRPp, QRPe and CW/SSB for
    Contesters interested in increasing their scores. It can also be of
    benefit to other Radio Amateurs to determine band conditions for Nets
    and casual QSO's. This information is NOT based on any software pre-
    dictions or any kind of satellite based readings. It is based on a
    new Ionospheric sounding method called "HF Ionospheric Interferometry"
    which operates very similarly to the PolSAR system used by NASA.
    Also, check out the VOACAP predication Web page at:
    http://www.voacap.com/prediction.html
    A daily HF radio wave propagation forecast can be found at:
    https://www.facebook.com/thomasfranklingiellaw4hm
    Also on Twitter: https://twitter.com/@GiellaW4hm
    QSL INFO AND NEWS...................
    QSL-INFO from DB0SDX by Lothar, DL1SBF (November 12th) <www.qslinfo.eu>
    3B9FR via M0OXO (O) HF40PLV via SP3CGK PA25ZWN via PI4ZWN
    4J3J via RW6HS (d) HF6FIRAC via SP6IEQ (B/L) PI4SRN via PA3DHR
    4U1A via UA3DX HF7ASQ via SP7VC PJ4/DL5CW via DL5CW
    4X/R1CC via DJ1ND HF7HB via SP7VC PJ4/DL5LYM via DL5LYM
    5B/RA1ALA via RA1ALA (d) HF7JX via SP7VC SP9IZ via K5QB (B/d)
    9A/IZ3NXC via IK3GES HG44DSL via HA1DSL TC630MECCA via TA3X
    C93PA via PA5X & (L) HG7T via HA7TM TM100LGG via F4GRW
    CT8/DL7AFS via DL7AFS HS0ZLP via DJ9ZB TM17PGM via F4FCE
    DK0HN via DJ5QE J68GD via K9AW (d/L) TM8OMC via F8KGN
    DU7/DK5EW via DK5EW LX/PC2D via PC2D (L) TR8CA via F6CBC (d)
    EA7/OG55W via OH2OT (O/L) MW5R via MW0EDX VP9/DK7LX via DK7LX
    EA8/DM6KG via DM6KG N4T via WN8Y W1H via KB1QXJ
    EA8/OH5ZN via OH5ZN OL1C via OK1ONA YB0ECT via W2FB
    FP5BZ via F5TJP OP17RCL via ON3AR ZW1CML via PY1CML
    H2X via IZ4AMS (d/O) OP8ON via ON8ON ZZ2Z via PY2GTA
    HB9/DF4WX via DF4WX OZ/KH6DXX via DF3XX ZZ8A via PY1MT
    (e) eQSL only (d) direct only (B) Bureau only (*-B) DX's- Bureau
    (O) OQRS only (C) ClubLog only (L) LoTW only (88) no QSL required
    LOGS ONLINE AT CLUBLOG.ORG THIS WEEK......
    https://secure.clublog.org/logsearch/4W/OZ1AA
    https://secure.clublog.org/logsearch/9U4M
    NEW QSL ROUTE 9N1AA. Dan, N4GNR, reports, "Satish, 9N1AA, has asked me
    to pick up his QSL duties...so QSL DIRECT to N4GNR. I understand that
    N4AA has a sack full of unanswered cards at his home up to the time of
    his death. I will be getting those cards this week, and I hope to have
    them answered within 2 weeks... and any cards that come in hereafter
    will be answered same day ... Again-- QSL DIRECT to N4GNR...
    73 Dan Cisson N4GNR"
    QSLS RECEIVED VIA LoTW: 9U4M, A5A, CN2AA, EA2VE, EL2EL, HB0/DL2SBY,
    JE7JDL, OK1VK, RI1ANO, RI1F (EU-190), RQ6M, TI2DYP, TX5EG, TY2AC,
    VU7T and ZS4JAN
    QSLS RECEIVED VIA MAIL: 5A5A, A25BE, NL6/AA7CH (NA-157), RI1F and
    TZ4PR
    QSLS RECEIVED VIA THE BUREAU: 4J90UD, 4U1GSC, 4U20B, 9L1A, CT9/DJ9RR,
    HH2/9A7GAE, HL4/JA8COE, IS0ANT, IS0DCR, JD1BON, SV5/DJ5AA, T8CW, T88KK,
    TJ3SN, V51LK, V51MH, XV9NPS, Z61KR and ZF2CJ
    SILENT KEY. It has been reported that the Associazione Radioamatori Italiani
    (ARI) President Pietro "Mario" Ambrosi, I2MQP, of Rodano, Millepini, Italy,
    became a Silent Key (SK) on November 6th, at the age of 74. Mario served for
    several decades at the head of Italy's national Amateur Radio organization
    and IARU member society. He was also a long-time ARRL member, DXCC card
    checker, and a 2005 CQ Amateur Radio Hall of Fame inductee. Ambrosi was a
    DXer and Contester, a member of the ARI DX Club Contest Team, and held #1
    Honor Roll and 9-Band DXCC. He also served as a QSL Manager for multiple
    stations and was an author of many radio books. OPDX and its readers would
    like to send out our deepest sympathy to the family and friends of I2MQP.
    ST, SUDAN. DXNews.com reports that Sergey, R4PBW, is currently active as
    ST/R4PBW from Khartoum, Sudan. Length of stay is unknown. He is using a
    Yaesu FT-847 transceiver and GP Antenna. QSL via eQSL.
    TI5, COSTA RICA (Update/Change). Chris, KL9A, will once again be active
    from Costa Rica, but as TI7W (not TI5W as first announced) during the
    CQWW DX CW Contest (November 25-26th) as a Single-Op/All-Band/High-Power
    entry. QSL TI7W via W4FS. Outside of the contest he will use the callsign
    TI5/KL9A. QSL TI5/KL9A via W2GR.
    V2, ANTIGUA. Frank, N2FF, will be active as V26FF from English Harbour,
    Antigua Island (NA-100), between November 15th and December 7th. Activity
    will be on 40/30/17 meters using CW, SSB and the Digital modes (RTTY and
    FT8). Look for him to be in the CQWW DX CW Contest (November 25-26th).
    QSL via LoTW. PLEASE, send NO cards to Antigua home callsign N2FF.
    V3, BELIZE. Michael, K5MDK, will be active as V31MK from Maya Hill Lodge
    near central Belize between March 1-5th. Activity will be on various HF
    bands. QSL via his home callsign, direct or by the Bureau. He also plans
    to operate with V31VP during the ARRL International DX SSB Contest (March
    4-5th). Watch QRZ.com for more details.
    VK, AUSTRALIA. Byron, KF8UN, is expected to be active as VK/KF8UN around
    and near the Brisbane area until January 14th. He will be using a G5RV
    antenna and running barefoot. QSL via his home callsign.
    VK9M, MELLISH REEF (Update). The VK9MA team continues to be active from
    Mellish Reef (OC-072) until November 16th. Activity is from Heralds-Beacon
    Islet, the only permanent land in the reef, on 160-10 meters using CW,
    SSB and RTTY. ClubLog.org shows as of 1628z, November 12th, the VK9MA team
    made 36771 QSOs with 12484 unique callsigns (8820/SSB, 25227/CW, 469/FT8
    and 2254/RTTY). Breakdown is: 151/AF, 14190/AS, 11197/EU, 9145/NA, 1777/OC
    and 311/SA. QSL via N7QT, direct, by the Bureau, ClubLog's OQRS (STRONGLY
    RECOMMENDED), LoTW or eQSL. All QSOs will be uploaded to LoTW and eQSL
    shortly after the operation. For more details and updates, see:
    https://vk9ma.com
    VP5, TURKS AND CAICOS ISLANDS (6m Op). Dave, W9DR, a well-known 6m op,
    will be active as VP5/W9DR from VP5-land (Grid Sq. FL41AW) between June
    13-25th, 2018. Activity will be on 6 meters (50.115 MHz) only using CW
    and SSB. Dave states that he will be using a SDR Transceiver, 1 KW, 5
    element Yagi, Beacon during slow periods, all salt water launch over
    North Atlantic to NA and EU/Mid-East." QSL via W9DR direct.
    VP9, BERMUDA (Change/Update). Tony, VE3RZ, will be active as VE3RZ/VP9
    from the VP9GE apartments on Bermuda between November 19-28th. Activity
    will be on various HF bands (especially 160/80m) using mostly CW, some
    SSB and the Digital modes (RTTY, FT8). He also plans to be in the CQWW
    DX CW Contest (November 25-26th) as a Single-Op/All-Bands/Assisted/
    Low-Power entry. QSL via M0URX's OQRS (direct and Bureau) or LoTW.
    VQ9, CHAGOS ISLAND. Kazeno, JO1GWT/KJ6ZHM, is once again active as VQ9KA
    near Diego Garcia. The length of his stay is unknown. If like last time,
    he will be on 40-10 meters using CW and SSB. He states that if it rains
    there will be no operation. Kazeno uses a Yaesu FT-857D into a Buddipole.
    QSL via JO1GWT, direct or by the Bureau.
    YASME NEWS (Press Release, dated November 6th). Kip Edwards, W6SZN,
    Secretary and Director of the Yasme Foundation, sent out the following:
    [edited] YASME FOUNDATION EXCELLENCE AWARDS AND SUPPORTING GRANT
    The Yasme Excellence Award is presented to individuals and groups who,
    through their own service, creativity, effort and dedication, have made
    a significant contribution to amateur radio. The contribution may be in
    recognition of technical, operating or organizational achievement, as all
    three are necessary for amateur radio to grow and prosper. The Yasme
    Excellence Award is in the form of a cash grant and an individually-
    engraved crystal globe.
    The Board of Directors of The Yasme Foundation is pleased to announce
    the latest recipients of the Yasme Excellence Award:
    Dayton Amateur Radio Association (DARA) -- to pick up the world's
    largest amateur radio event on a few months notice and move it to a
    completely different facility is a daunting task. That it went so
    smoothly was a testament to the extraordinary efforts of the 600
    volunteers and event leadership.
    Paul Verhage, KD4STH, and Bill Brown, WB8ELK -- for their leadership
    and continued technical innovation in amateur radio high-altitude bal-
    looning (ARHAB - <en.wikipedia.org/wiki/High-altitude_balloon>). While
    not the traditional means of introduction, ARHAB is exposing hundreds
    of students to amateur radio through an interest in science experimen-
    tation. Both have written extensively about ARHAB and have contributed
    material to the ARRL Handbook.
    Nathaniel Frissell, W2NAF and Magda Moses, KM4EGE -- for creating and
    leading the HamSCI (Ham Radio Science Citizen Investigation) organization
    that sponsored the Solar Eclipse QSO Party (SEQP). The SEQP was the
    largest amateur radio experiment ever devised and generated the world's
    most extensive set of HF propagation observations during an eclipse.
    Beyond the SEQP, HamSCI is attracting the interest of professional/
    academic researchers such as from numerous universities, the Arecibo
    Radio Observatory in Puerto Rico, MIT’s Haystack Observatory, and HAARP
    facility in Alaska.
    The WSJT Development Team -- initially the work of Joe Taylor, K1JT,
    the WSJT software is now maintained and extended by a team of developers
    led by Bill Somerville, G4WJS; Steve Franke, K9AN; Greg Beam, KI7MT;
    Michael Black, W9MDB; Edson Pereira, PY2SDR; and Nico Palermo, IV3NWV;
    along with Joe Taylor. Their latest digital mode, FT8, combines the
    extraordinary low-SNR performance of JT9 and JT65 with a much faster
    decoding and exchange process.
    Dale Hughes, VK1DSH, -- for his excellent work as Chairman of the
    Amateur Working Group in ITU-R Working Party 5A and as Chairman of the
    sub Working Group dealing with a worldwide 60 meter amateur allocation
    during World Radiocommunication Conference 2015.
    The Board also made a grant to Gary Pearce, KN4AQ, for his production
    and distribution of videos of interest to the amateur radio community
    through Ham Radio Now and YouTube.
    The Yasme Foundation is a not-for-profit corporation organized to support
    scientific and educational projects related to amateur radio, including
    DXing (long distance communication) and the introduction and promotion
    of amateur radio in developing countries. For additional information
    about The Yasme Foundation, visit our website at <www.yasme.org>.
    Ward Silver, N0AX, President The Yasme Foundation
    Board of Directors: Ward Silver, N0AX, President and Director
    Ken Claerbout, K4ZW, Vice-President and Director
    Rusty Epps, W6OAT, Treasurer and Director
    Kip Edwards, W6SZN, Secretary and Director
    Hans Blondeel Timmerman, PB2T, Director
    Martti Laine, OH2BH, Director
    Fred Laun, K3ZO, Director
    Robert Vallio, W6RGG, Director
    ZA1WW & Z60WW -- ALBANIA & KOSOVO IN THE CQWW CW CONTEST (Press Release
    from Pristina, Kosovo, dated November 11th). Kip Edwards, W6SZN, sent
    out the following: The Kosovar Amateur Radio Association, SHRAK with the
    National Association Radioamateurs of Albania, NARA are organizing a
    multi-multi effort from the coastal city of Durres in Albania. Fehmi,
    Z62FB, and Fatos, ZA1F, are leading the team of locals plus their invited
    guests.
    Vjollca, Z61VB, the president of SHARK, observes that these exchange
    programs are necessary for the time being while waiting for Kosovo itself
    to count for DXCC. As a CQWW multiplier, however, their HQ station Z60A
    would be operated as Z60WW by seasoned contester Olli Rissanen, OH0XX.
    ZF, CAYMAN ISLANDS. Dan, N6MJ, will once again be active as ZF2MJ from
    ZF1A QTH on Grand Cayman Islands (NA-016) during the CQWW DX CW Contest
    (November 25-26th) as a Single-Op/All-Band entry. He will be on the island
    between November 20-28th. Activity outside of the contest will be on
    160-10 meters including 30/17/12 meters. QSL via N6MJ or LoTW.
    ZP, PARAGUAY. Manu, ZP9MCE, will be active from Hohenau-Itapúa during the
    entry. QSL via EA5ZD only.
    TO BE ADDED TO THE OPDX MAILING LIST -- Click or send requests to:
    Help: <mailto:eek:pdx-request@barf80.org?subject=help>
    Subscribe: <mailto:eek:pdx-request@barf80.org?subject=subscribe>
    Unsubscribe: <mailto:eek:pdx-request@barf80.org?subject=unsubscribe>
    OPDX WORLD-WIDE WEB HOME PAGE (provided by John, K8YSE):
    http://www.papays.com/opdx.html
    ALSO VISIT THE NORTHERN OHIO DX ASSOCIATION'S WEB PAGES AT:
    http://www.nodxa.org/
    http://www.facebook.com/NorthernOhioDxAssociation
    * All excerpts and distribution of "The OPDX Bulletin" are granted as
    long as KB8NW/OPDX/BARF80 receives credit.
    ** To contribute DX info, please send via InterNet Mail to:
    <kb8nw@barf80.nshore.org> OR <kb8nw@arrl.net> OR <kb8nw@hotmail.com>
    Information can now be faxed to the following phone line at:
    1-419-828-7791 (F A X only!)
    /EXIT
