NVIS Ant for qrp
Discussion in 'QRP Corner' started by KD2RON, Mar 6, 2017.
ad: OK1UUad-1
  1. KD2RON
    KD2RON Ham Member QRZ Page
    I used a NVIS on 40m with 100w with good results two years ago. It was a dipole about 7 ft high with three reflictor wires on the ground. I was thinking of making a portable version for this summer for qrp-ish use (rig puts out 7-8 watts). Anyone use NVIS with qrp ? Any reason not to? Thanks
  2. KA5IVR
    KA5IVR Premium Subscriber QRZ Page
    I wouldn't think Watts would matter more than watts normally do for any other antenna. Hopefully the band is working when you try.
  3. KL7KN
    KL7KN Ham Member QRZ Page
    I used a PRC-104/AS-2259GR for a number of years. 20 watts. Worked fine most of the time, again, as noted, if the bands are working.
    Good luck, a NVIS can make a marked difference for contact s up to ~300 miles.
  4. KL7AJ
    KL7AJ XML Subscriber QRZ Page
    Since NVIS uses the lower frequency bands, you will have the same issues whenever running QRP. Absorption tends to be a lot higher on the lower bands. However, it's worth a try. For optimum NVIS, you want to be operating about 10% below the critical frequency, so it helps to become familiar with local ionosondes.
    Eric
    AI3V and W9AMM like this.
  5. W6OGC
    W6OGC Ham Member QRZ Page
    I bet you did not know that term "NVIS" is derived from an old Indian expression meaning "the smoke goes straight up."
    AD5KO, WC3T and KA0HCP like this.
  6. KD2RON
    I hope my 7watts doesn't smoke up to many clouds.
  7. KB7NRN
    KB7NRN Ham Member QRZ Page
    I have used an FT-817 and IC-703 with a 40mtr NVIS antenna. I tried it in the woods on the back side of my property and when out hiking in the Cascade Mtns.
    With the 817 I only ran 0.5-1.5 watts and the 703 was running 5 watts. All SSB contacts. Had no problem getting out. Contacts maxed out to 300-400 miles or No. Cal to northern Washington state but the best contacts (S-9) were within 100 miles of where I was set up western Oregon.
    KD2RON likes this.
  8. W1VT
    W1VT Ham Member QRZ Page
    http://hfpack.com/propagation/
    Check out this map at the appropriate times to see whether or not you have any NVIS propagation on 40. The low solar flux numbers have really affected 40M NVIS--the openings are a lot shorter than they use to be just a few years ago.
    KD2RON likes this.
  9. K8JD
    K8JD Ham Member QRZ Page
    My Idea for a NVIS antenna is something like a dipole of full wave loop up a quarterwave . Your 7 ft high antenna is a dirt warmer. Half it's near field is underground !
    . I have run QRP on an 80M dipole up 0.12 wavelength high and a 40M square loop up 0.25 wavelengths and this worked very well. My 160M dipole is only up 0.07 waves but it is a work in progress. It works fairly well where it is, worked east, Gulf, and west coast with it and 100 W. Very Strong signals in the surrounding states.
    I ran a dipole up about 25 ft on 80M when I was a novice and worked all over s. MI, n OH, n. IN and s. ON with about 4 W. Back then nobody called it NVIS :D
  10. KF5FEI
    KF5FEI Ham Member QRZ Page
    We made a tuned version of the military NVIS antenna and it works great on 40 meters. (20m and 40m inverted Vs from same feedpoint @ 16 feet) The first time we tried it was for the Texas State Parks On The Air contest, running an FT-817 on 40m phone. We were getting signal reports equal to 100 watt stations and won the QRP category on our first attempt.
ad: wmr-1
