non Ten-Tec keyers and Omni C
Discussion in 'Working Different Modes' started by N9FB, Sep 29, 2010.
  1. N9FB
    N9FB Ham Member QRZ Page
    Recently I acquired an Omni D Series C and sold my Argonaut V. I am in heaven as this was the rig I used to dream of as a teen...
    My question is regarding keyers. Does anyone know if an old Nye Viking SSK-1-K will work with it? I have read some old ten-Tecs require a reed relay in between or one can harm the rig.
    The Omni C manual says the following:
    "Electronic keyers other than Ten-Tec models preferably should be of the reed relay type, since a low resistance to ground contact is required on the key line for proper transmitter keying."
    anyone able to translate that for me?
    I was looking for a Ten Tec 645 but only heard from a few guys overseas and the cost was too high.
  2. N4SNB
    N4SNB Ham Member QRZ Page
    Keyer for OMNI C
    Hello K9AIM,
    Congrats on getting one of the best CW rigs ever made. I have three, two working and one for parts.
    Im driving mine with a N0XAS Picokeyer-Plus Kit that I purchased a couple of years ago for $18 plus shipping. The rise and fall characteristics are sharp and produce a very nice signal out of the OMNI C. The coin battery draws current only on a dit or a dot and mine is still working after almost two years. I use a Vibroplex Vibrokeyer to drive the chip.
    Anyway, the website is worth visiting even if you dont like the keyer.
    http://www.hamgadgets.com/store/product_info.php?products_id=89
    I check-in on the Sunrise Net each morning about 1300Z on 7.123 mhz if you want to hear one drive an OMNI C . Its a very informal net, hope you can stop by.
    73's N4SNB
  3. AI3V
    AI3V Ham Member QRZ Page
    Translation:
    "Some keyers will not be zero Ω on the transmitter keying line when you are sending.
    These few Ω may cause the OMNI to not transmit properly.
    Using a reed relay between the keyer and rig will correct this problem IF it occurs.
    Better still would be to install a transistor switch between the keyer and rig, this will eliminate the possibility of a bad mechanical contact on the reed relay, and any slight timing issues with the mechanical relay"
    Rege
  4. W1VT
    W1VT Ham Member QRZ Page
    An NPN transistor will have a collector to emitter voltage drop of several tenths of a volt--maybe more if you don't drive it hard to make your batteries last longer. Modern FET switches are much better having a drain to source channel that looks much more like a very low resistance, but they weren't cheap when the Omni D was introduced. Also, modern FETs have capacitive inputs, which means the minimum drive power is proportional to switching speed--they can be extremely efficient in low speed circuits compared to bipolar transistors.
ad: Schulman-1
