No audio on 2m and 70cm on 991a
Discussion in 'General Technical Questions and Answers' started by KN6KKW, Mar 18, 2021.
Tags:
  1. KN6KKW
    KN6KKW Ham Member QRZ Page
    I have a 991a and for some reason the audio doesn't work on 70cm and 2m. HF audio is fine but not on those 2 bands. I've tried plugging in headphones and still nothing. I can see signals coming in and can hear them on my HT but not on the 991a.
    Any idea what might be wrong? I'm just using a gp-1 antenna directly connected to the radio...signal looks strong on the waterfall but no audio at all.
    Thanks
  2. PA5COR
    PA5COR Ham Member QRZ Page
    Look in the F Menu settings if you acidentally don't have the tone/dcs switched on in recieve.
    Then the receiver is waiting for a digital tone to open the receiver, if that is not there it won't open audio.
    Check with going through the menu and see if pushing SQL OFF gives audio.
    IF so, put TONE/DCS on offf for receive.
    Normal squelch will work then.
    KU3X and PY2RAF like this.
  3. KN6KKW
    Thank you! Turning off the tone seems to have worked. It was on ctss before and it works when its off and when it is on d.enc
  4. G8FXC
    G8FXC XML Subscriber QRZ Page
    Bummer, that, isn't it? I spent something like 15 minutes at the weekend wondering exactly the same before I checked what should have been obvious!
    Martin
    KN6KKW likes this.
  5. PA5COR
    We all have our "blonde"moments ;)
    With my FT991A i had the same, so been there done it, got the T shirt...
    KN6KKW likes this.
