Newbie - Need Some Guidance on Grounding My Shack
Discussion in 'General Technical Questions and Answers' started by KC1OUL, Mar 25, 2021.
  1. KC1OUL
    KC1OUL Ham Member QRZ Page
    Hi Everyone,
    I am new just having obtained my license a few days ago. I am now trying to figure out what I need to setup a shack. I am wondering if someone could help me understand grounding to ensure I have it right.
    It is my understanding that I need to ground all my equipment to a single point - a copper pipe or bar and then ground that to my outside ground - the same one grounding my electrical service.
    So some questions:
    1.) Can I use any copper braid to connect my equipment to a pipe/bar or is there a recommended width?
    2.) What is the recommended material to connect the bar to the outside ground? Is it copper strap? Any strap?
    3.) I know I have to keep the run from my bar to the outside ground as short as possible, but is there any guidance on this? What is too long?
    4.) Lastly, I am looking to get on 20m to start using a dipole. Does the dipole need to be grounded to my grounding rod as well? I am seeing some conflicting information out there about this.
    This is all new to me, so please excuse my ignorance. However, you have to start somewhere.
    I appreciate the assistance.
    KC1OUL
  2. K1LKP
    HELLO LISA,
    WELCOME TO THE WONDERFUL WORLD OF HAM RADIO.
    IF TIME ALLOWS STOP BY MY QRZ PAGE AND GO TO THE SECTION ON
    GROUNDING...... LOTS OF GOOD SCOOP.
    YOUR QRZ ADDRESS SHOW YOU LIVING UP IN VERMONT.
    BECAUSE OF UR VERY COLD COLD WINTERS, I RECOMMEND THAT
    YOU PURCHAS A 10 FOOT GROUND ROD. SOLD AT HOME DEPOT
    YOUR BEST BET IS TO DIG A DEEP PIT SO THAT YOU CAN GET THE
    TOP OF THE ROD BELOW THE FROST LINE.
    HOPEFULLY ALL THE ZEDDERS (QRZ FOLKS ) WILL BE ABLE TO
    POINT U IN THE CORRECT DIRECTION WITH THEIR INSIGHT
    REGARDING UR QUESTIONS:
    So some questions:
    CHECK OUT THIS WEB SITE:
    WWW.GACOPPER.COM/
    COPPER STRAP IS GREAT CHOICE
    HOPEFULLY, YOUR RADIO SHACK IS ON THE FIRST FLOOR OR IN
    THE BASEMENT PORTION OF UR HOME.
    YOU SHUD TRY TO SET UP A BUS BAR FOR UR SHACK GROUNDING
    ALSO.... THIS STUFF IS GREAT TO USE.
    ANY HARDWARE U PURCHASE TO CONNECT TO UR GROUND ROD SHOULD
    BE WHAT THEY CALL "BURIAL RATED"
    THERE IS A LOT OF CONFLICTING INFORMATION ON THIS MATTER.
    TAKE IN ALL THE SUGGESTION THE ZEDDERS WILL PROVIDE AND
    THEN DO A LOT OF READING ON YOUR OWN. THERE ARE SO MANY'
    SITES ON THE INTERNET THAT CAN GUIDE YOU.
    WORK SAFELY AND BE SURE THAT WHEN U DRIVE DOWN UR
    GROUND ROD --- U DON'T END UP DRIVING THE ROD INTO A WATER /
    ELECTRIC / GAS LINE/ SEWER.
    WE WERE ALL NEW BEES AT ONE TIME...HAVE FUN....
    73 ES WORK SAFELY
    KE8OKM likes this.
  3. W6KCS
    W6KCS Ham Member QRZ Page
    Not really. In olden times before equipment had grounding plugs grounding the chassis, it was nice to ground everything AC-powered to keep the chassis at the same potential and for fault clearing (shock protection).
    You should have a surge arrestor at the antenna entry, grounded as close to the dirt as possible, ideally right to the house service ground or a ground rod bonded to the house service ground. There's some good info here: http://www.repeater-builder.com/tech-info/bonding/amateur-radio-bonding.html
    KC1OUL likes this.
  4. KC1OUL
  5. KC1OUL
    Awesome. Thank you so much!
    K1LKP likes this.
