Negative peak greater then the Postive
Discussion in 'Amplitude Modulation' started by WA4JK, Jun 6, 2020.
  1. K8ERV
    K8ERV Ham Member QRZ Page
    There you go with them big words------
    TOM K8ERV Montrose Colo
  2. WA4JK
    WA4JK Ham Member QRZ Page
    Still having the issue, yes it certainly could be operator error or maybe not... This ain't my first rodeo, any cowboy can buck off... So can you
  3. N2DTS
    N2DTS Ham Member QRZ Page
    Power supply sag, low grid drive and/or bias, wimpy mod tube, wrong modulator bias, shorted turns in mod transformer, low emission of class c final tube/s.
  4. KA9JLM
    You don't want to share with others. o_O
    I am not going to share my Beef Jerky with you. :p
  5. WA4JK
    I have new mod tubes in and no sag in the power trany. I measured the bias and it’s good. It most likely the audio string run by the duffas behind the key.
    I’ve adjusted everything to where the negative does not hit 100% and reports from the audience is it’s sounds good and that’s good enough for me.
    As to why the negative is larger than the positive at times at certain voice peaks? It might be the bc610 mod Iron limits or something I’m going to have to study about. Until then it works good enough to not bother others.
    Thanks
    No soup for you
  6. AC0OB
    Negative peak greater th[a]n the Positive [peak]
    What is your baseline level for, and how are you measuring your waveforms?
    Pheel
  7. N2DTS
    Just because the modulator tubes are new does not mean one has more output then the other.
    I try and put the better tube in the positive side.
