Need some help with new radio
Discussion in 'Youth Forum' started by KG7FLL, Dec 25, 2013.
  1. KG7FLL
    KG7FLL Ham Member QRZ Page
    I got a Yaesu FT-2900R for christmas. Whenever I run the radio at full power(75 watts) it shuts off and comes back on. Does anyone know why it does this and or help me? Thanks!
    -KG7FLL
  2. K9ASE
    K9ASE XML Subscriber QRZ Page
    Do you have any idea what the SWR is between the radio and antenna? If there is too much of a mismatch the radio will shut off to protect itself.
  3. WA8FDY
    WA8FDY Ham Member QRZ Page
    Is the power supply large enough to handle the needs of the radio @ 75 watts?
    73, Doug
  4. KB3ZYN
    KB3ZYN Ham Member QRZ Page
    You may have a power supply issue, as well, but I concur with FLL on this one.
  5. KG7FLL
    that I dont
  6. KG7FLL
    Yeah. But its not that new
  7. M6RIK
    M6RIK Ham Member QRZ Page
    Could also be a bad power connection. Check everything even the connection between the power line and the in line fuses.
  8. KJ4WZH
    KJ4WZH Ham Member QRZ Page
    my icom 7000 did this. it has a fuse in the positive and negative power cable when one of them blows it does this.
  9. W5BIB
    W5BIB Premium Subscriber QRZ Page
    I would suspect SWR...
    check the manual in the "problems" section.
    or,... ask a local ham. (via club, e-mail)............
    If it stays on at "lower power" ... it's more than likely SWR (mis-match problems).....
    Let us know if ya get it figured out.....
  10. W8NGA
    W8NGA Ham Member QRZ Page
    Could you please tell us more about the power supply that you're using and the antenna? Also, what kind of cable are you using between your radio and antenna?
    Greg W8NGA
