Need manual for AEA PK-80 packet TNC
Discussion in 'Working Different Modes' started by K3RW, Jun 6, 2018.
Tags:
  1. K3RW
    K3RW Ham Member QRZ Page
    I'm borrowing a PK-80 to try packet (I know, I know). I can't seem to find a manual anywhere online. I've got a cable that needs pin-outs but no idea what goes where.
    FWIW, I'll probably borrow a PK-232 soon. But I'll need a manual for that one too, if you can point me to a pdf online.
  2. W9GB
    AEA PK-80
    CPU : Z80-A
    Clock : 2.4576MHz/4.9152MHz (changed by jumper)
    Memory : ROM 32KB RAM 8KBx2 or 32KB (must use 32KB after firmware 1.1.4)
    Serial : Zilog Z8440 SIO
    RS-232C 300/1200/2400/4800/9600bps D-SUB 25- pin (DB-25)
    Modem MF-10 filter XR-2211 Demodulator XR-2206 Modulator
    Protocol AX.25 Level 2 Ver 2.0
    Power : 11-15V DC
    Less than 200mA (less 100mA by CMOS)
    The AEA PK-80 modem was released in late 1986 / early 1987 (as I remember).
    http://www.geocities.jp/tnc_gallery/pk80-e.htm
    The PK-80 was AEA's clone of the TAPR TNC-2.
    Still good for 1200 bps packet and is upgradable with add-on modems for 9600.
    Virtually identical to TNC-200(Paccomm), MFJ-1270(MFJ) and TNC-2A(GLB).
    Suggest upgrading the firmware with latest TNC-2 or PacComm Tiny-2 firmware.
    TAPR
    https://www.tapr.org/kits_119.html
    TAPR TNC-2 : System Manual (1992)
    http://aprs.facile.free.fr/pdfs/TAPR TNC2 rev2 system manual1.1.8.txt
    TAPR TNC-2 Kit : Assembly Manual
    http://www.radiomanual.info/schemi/ACC_packet/TAPR_TNC2_Rev2_assembly_manual.pdf
    March 12, 2009 Thread on TAPR (aprssig).
    http://www.tapr.org/pipermail/aprssig/2009-March/028901.html
    Byron, K6ARP / WA6YLB was using a PK-80 for packet.
    http://ember2ash.com/k6arp.htm
    Repeater Builders TIP : AEA Manuals (PK-80 not on-file)
    http://www.repeater-builder.com/aea/aea-index.html
  3. N6QIC
    N6QIC Premium Subscriber QRZ Page
    It should be the same as the PK-88 I have 2 and 2 manuals.
    Just go and buy a serial cable from your local computer store and plug it in. You will also need a serial card in the PC and a terminal program.
    The PK-88 TNC can also be directly connected to a Wyse - 50 terminal via the serial cable. I would think the PK-80 is connected the same way.
    Also use the same cable with the PK-232 TNC.
    K3RW likes this.
  4. W9GB
    K3RW likes this.
  5. K3RW
    I borrowed a PK-232 the other day. Hopefully this one will have better capability and ease of setup.
  6. N2SUB
    N2SUB Premium Subscriber QRZ Page
    I do not recall it needing a null modem cable, I thought it was a straight serial cable. A null modem cable would have him cursing up a storm, and there's no real identifiable marking to tell the difference (this is the voice of experience speaking ;) ).
    K4AGO and N6QIC like this.
  7. N6QIC
    That could very well be, the same as the picture a DB25 Male to DB9 Female serial cable. It has been a long time, I still have my original cable hooked up to the TNC. It all still worked a year ago on my old Win-95 box, but no one on packet to talk to.
    N2SUB likes this.
  8. K3RW
    I'm looking at the box now... it was set up to have Radio 1 on some sort of special pin connector to a mic jack and a tiny headphone jack thing. Not sure but I'd guess it was originally set up on a pre-706 ICOM with the round pin connector in the front.
    Seems I could potentially order the special cable from MFJ (*gasp*), but not sure if it needs the roundish accessory looking plug one, etc. I would likely use it on a 7100 since it has VHF/UHF/HF capabilities.
  9. K2WH
    K2WH Premium Subscriber QRZ Page
    I sold my PK-80 manual and PK80 Modem on Ebay about 1 year ago, had it since the 1970's.
    What I do when looking for something that rare, I do a search on Ebay and then when its not found, you can save the search and you will be notified via email or phone when it appears, if ever.
    It works great. Scored an old and rare ICOM 215 FM rig that way.
  10. W9GB
    Repeater Builders
    Advanced Electronic Applications, Inc. (AEA) Index Page
    Compiled by Mike Morris WA6ILQ
    Maintained by Robert Meister WA1MIK
    TAPR continues to sell the TAPR TNC-2 EPROM, version 1.1.9 with KISS
    Vintage Manuals sells Paper Copies of the PK-80 manual.
    http://www.vintagemanuals.com/manual/AEA/PK-80
    Pre-Wired TNC-2 (5-pin DIN) cables to various Radios are sold by MFJ.
    http://www.mfjenterprises.com/Product.php?productid=MFJ-5084
    Too Expensive?
    Then DIY Skills are required for the Frugal, Penny-Pincher, or Economically Challenged.
    K3RW likes this.
