need help with my 55 ft crank up
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KN4OK, Jun 3, 2021.
  1. KN4OK
    KN4OK Platinum Subscriber Platinum Subscriber QRZ Page
    I have a 55 ft crank up tower. I went to lower it and of course, started cranking it up. I paused a a few, then went to reverse it and the lock nut broke lose. I am sure I need to replace that nut, but is that all? Thanks in advance for replies.
  2. WA7ARK
    WA7ARK Ham Member QRZ Page
    I was given a TX455 with a hand crank. That OEM "boat trailer winch" that came on it was a piece of crap. It now has a electric winch with limit switches.
    K0UO likes this.
  3. WB2WIK
    My TX-455 had a Fulton winch with a brake.
    Maybe you had an older model (or, maybe even a "newer" model).
    My winch is fine, it just takes lots of cranking so I almost never crank it down.:p
  4. K7MH
    K7MH XML Subscriber QRZ Page
    Helps to know for sure just what make and model the winch is.
    You can get parts breakdown/lists for the Fulton winches which should help.
  5. W9GB
    Fulton Performance, 2021 Catalog on their web page
    https://www.fultonperformance.com/
    Fulton Brake Winches
    https://www.fultonperformance.com/products/winches/brake-winches
    Fulton Performance
    47912 Halyard Drive, Suite 100
    Plymouth, MI 48170
    Telephone: +1-800-632-3290
    Customer Support / Inquiries
    https://www.fultonperformance.com/ContactUs
    FultonĀ® is a Registered Brand of Horizon Global Corporation
    With more than 100 years of impeccable performance,
    the Fulton line of trailer jacks, winches, and couplers has become the industry standard for light and medium-duty trailering.
    Founded in 1911, Fulton has expanded its offerings and, when combined with a CPP hitch, can outfit your weekend at the lake.
  6. W9GB
    Fulton K-1550 0101 Brake Winch, 1500 Lbs Load Capacity
    https://images.carid.com/fulton/items/pdf/kx10510101-installation-instructions.pdf
    • 1500 pounds maximum capacity, Self-activating automatic brake winch holds load securely
    • Drum Storage Data: 70 foot x 1/4 inch winch cable, 2 1/2" hub
    • 11 inch handle, Gear Ratio: 5.1:1
    • Z-MAX 600 Zinc finish to resist corrosion
    • Limited 5 Year Warranty
    Jim, NH6HI offers Rebuild Kits for the Fulton K-1550 Brake Winch at $39. See details in this thread:
    https://forums.qrz.com/index.php?threads/fulton-winch-k-1550-rebuild-kits.765982/
    KN4OK likes this.
  7. KN4OK
    Thank you
