Need help identifying 2-meter / dual-band "base" antenna
Discussion in 'Antennas, Feedlines, Towers & Rotors' started by KE0RG, Aug 9, 2020.
  1. KE0RG
    KE0RG XML Subscriber QRZ Page
    I've been having a difficult time trying to identify a vertical base antenna that I got from the estate of an /sk ham.
    The only sticker on it are what appears to be a warning or caution sticker, but is unreadable... and I've not found any stamped, etched, engraved, or cut markings that would help to identify the make or model.
    It is approximately 6 ft high (the main radiator, that is. Overall, it's about 8 ft), one-piece fiberglass. Designed to be used as a vertical base antenna.
    There are four radials sandwiched between two plates as a base. They are 90° to each other, and 90° to the plane of the antenna (horizontal).
    The coax connection is an N-connector and is below the base plate, but at about a 45° angle to the plane of the antenna and the radials.
    I know that this antenna works on 2-meters just fine, and it looks like it might be a dual-band (2-meter & 70-cm) antenna, but I haven't been able to test it on UHF yet.
    If anyone out there could point me in the right direction to start looking for information that seems to match this antenna, I would be very grateful. Thank you!
    [​IMG] [​IMG] [​IMG]
  2. KD7RF
    KD7RF XML Subscriber QRZ Page
    KE0RG likes this.
  3. KE0RG
    Thanks Mike!
    It does look like a Hustler antenna! I don't know why I never checked Hustler when I was searching. I'm glad you got me looking in the right direction.
    Still not sure which model I have... but now I have a place to start.
    My antenna looks like a G6-270... but has the radials of the 2-meter-only units. I'll have to do some digging.
    Thanks again Mike, and 73!
  4. KD7RF
    You’re welcome! Each radial on my G6-270R is 20.25”. The overall length of the antenna with mount is 101.5”.
    KE0RG likes this.
  5. KE0RG
    Bingo! Sounds like a match!
