Muddy reception in VX-7r
Discussion in 'Radio Circuits, Repair & Performance' started by KJ6HZH, May 31, 2018.
  1. KJ6HZH
    KJ6HZH Ham Member QRZ Page
    I've completed repair of my Yaesu VX-7, which was suffering from DC-induced damage to its ceramic filters. I followed http://pages.cs.wisc.edu/~timc/e/vx7r.html and the blocking capacitor notes at the bottom of the page. My results can be seen at https://www.flickr.com/photos/32548582@N02/albums/72157667529801877. The repair appears to have been a success.
    The next day, Wed May 30, I turned on both my VX-7 and FT-8800 to compare the reception. There was a net going on at 145.230 (w7bpd) transmitting from atop Sumas Mountain in northwest Washington, around 30 miles ENE from me. That repeater pegged both radios. The FT-8800 reception sounded very good. The VX-7 reception had bits of static and crunches. This was helped slightly by turning on the VX-7's attenuator and by using a rubber duck antenna. I also tried using the attenuator on the VX-7 and putting it on the FT-8800's antenna; an N9TAX slimjim hanging from a high ceiling. That was pretty good, but still not as good as what I got from the FT-8800.
    Other repeater and simplex reception doesn't provoke this response in my VX-7. Both radios put out audio of the same quality, albeit the VX-7 always sounds a bit tinny because of the speaker itself.
    What's going on here?
  2. G3YRO
    G3YRO Ham Member QRZ Page
    So you're saying that when you put your handheld on a PROPER antenna, and the signal is very strong, you're getting various distortion and noise problems?
    Well surely you know the answer . . . your handheld is being overloaded! (your mobile rig is obviously more sophistcated, and can cope with the very strong signal)
    At least you can HEAR the station . . . if you tried putting a Beofang handheld on a proper antenna, you wouldn't hear ANYTHING, as the front end would be swamped by all the signals between 100 and 500 MHz ! (although just on their small helical antenna, the Beofangs work as well as any expensive handheld)
    Roger G3YRO
  3. KA9JLM
    The proper antenna for a Baofeng is the one that comes with it.
    There is no "Better" antenna, Just antennas that cost more than the radio.
  4. KJ6HZH
    I understand those points. I don't understand why I don't get similar distortion when transmitting 50 watts from my mobile to the handheld 40 or so feet away.
  5. G3YRO
    Probably because when the handheld has a decent antenna on it, it's a COMBINATION of the strong Repeater signal mixing with some other strong signal (like a Pager transmitter or other commercial out-of-band signal) that is causing the distortion you are hearing.
    So it's not JUST the fact that the signal is strong . . . it's the fact that the handheld will be picking up SEVERAL strong signals causing intermodulation products in the front end.
    Roger G3YRO
  6. W2WDX
    W2WDX Subscriber QRZ Page
    I've used a VX-7r for years. They are not that susceptible to overload as other HT's. I live in New York City where repeaters and other RF sources are everywhere nearby. The VX-7R is very good at dealing with things like IM issues.
    I would try doing the comparison between the two transceivers with a pair of headphones, this way you can truly judge if the differences are in the electronics, or just a problem with the respective speakers.
  7. VE1IC
    VE1IC Ham Member QRZ Page
    check the 455khz filter
  8. KX0Z
    KX0Z Ham Member QRZ Page
    he just replaced those, its a common fault with the VX7R, mine has a dead IF filter and is partially deaf..
