Motorola Astro Rear Accessory Connector
Discussion in 'General Technical Questions and Answers' started by TA3N, Jun 18, 2020.
  1. TA3N
    TA3N Ham Member QRZ Page
    Hi. I bought a Motorola Astro but the Rear Accessory Connector is missing so I couldn't use the radio. It can not be used without the correct connecter. Radio has a code that enables it to operate with right short circiuts on that Rear Accessory Connector. Can anyone help me and explain how to enable the radio? I don't know which pins are the right one to use short circuit to trick it to give access to the radio. And also the speaker is actived with one of these circuit, I don't know which one activates speaker too.
    Thanks in advance.
    73.
    TA3N
    Sezgin Kenar
  2. WA6SW
    WA6SW Ham Member QRZ Page
  3. N2ZD
    N2ZD Ham Member QRZ Page
    It’s been so long, but the connector needs to be jumped so you have audio if I remember.
    Batlabs can help as the poster said above..
  4. KB0MNM
    KB0MNM Ham Member QRZ Page
    Some of the 'Astro' Radios have 'ignition sense', meaning that you do basically have a 'brick' unless the appropriate pins are jumpered for simple 12 VDC power-on control. Since 'Astro' is a series of radios and probably refers to one of a number of Spectra ( more specific ), MCS2000, etc. models- the information that is needed is in a long model number which is usually attached to the underside of the radio. In some cases, the radio must be removed from a lockable mounting plate to get that information. Your photo shows just a little bit of information: T99OX-092W_ASTRO. You need to see if you can photograph more of that sort of alpha-numerical information. Because the control-head also has information, look for a small bar-code on the underside of that, as well. A front view might allow an educated guess as to model series, which is also needed for decoding which 'Astro' radio you are dealing with.
  5. TA3N
    Firstly, thank you for your replies. I am finally able to start the radio. I found which pins to jump.
    You need to jump 2 and 8
    5th pin is +12 volts
    6th pin is the speaker (+)
    7th pin is the speaker (-)
    Here is my actual connector that I use for my radio to operate and it works. Have a nice day.
    73.
    TA3N
    Sezgin Kenar
