Morning QRP Friends!
Discussion in 'QRP Corner' started by W5KYP, May 9, 2017.
ad: OK1UUad-1
  1. W5KYP
    W5KYP Ham Member QRZ Page
  2. WN1MB
    WN1MB Ham Member QRZ Page
  3. W5KYP
    I don't know how well it would work, but I would like to try and make a 80 meter coil for a vertical.
    I've never made a coil before. Where would I start to educate myself on the construction on an 80 meter induction coil for a vertical?
    I already have a homebrew buddipole, so hope to build upon that. Anyone have any ideas?
    Thanks!
  4. N8AFT
    N8AFT Ham Member QRZ Page
    You may want to consider beneith the metal helipad but that would take some climbing and use of fall protection.
  5. KI6J
    KI6J Ham Member QRZ Page
    A 30+ foot fiberglass extending pole with a single wire, a loading coil with shunt feed at the base, and a magnetic welder's ground lug for the ground plane connection (if you can find bare metal).
    What a location!
    N6MST likes this.
  6. N6MST
    N6MST Ham Member QRZ Page
  7. W5KYP
    I have a Jackite 31' pole that I use for my endfed, its too long collapsed to fit in the helicopter.
    I also have to keep in mind that if I set anything up on the helideck, I have to be able to remove it in less than 10 minutes.
    When a helicopter is coming in we get a 10 minute call for a green deck, any longer than that and I will be in big trouble!!!
  8. KI6J
    Here's a 30m vertical I used a few times on top of a steel water tank. The element is a 12 foot extending whip (Buddipole makes one); the loading coil is wound on some PVC scraps with 3/8" hardware; the mag-mount base has a PL to 3/8" adapter screwed into it. Since mag mount coupling is insufficient at HF, I used the legs of a 30m dipole clipped onto the adapter as radials. The whole thing collapsed into a small stuff bag. Put small magnets at the end of the radials to keep them from blowing around.
  9. KI5WW
    KI5WW Ham Member QRZ Page
    Fun suckers.
  10. KL7AJ
    KL7AJ XML Subscriber QRZ Page
    Have you tried loading up the helipad itself?
