ad: Stlouis-1
Mobile HF and which antenna
Discussion in 'On the Road' started by WD8G, Sep 7, 2014.
  1. WD8G
    WD8G Ham Member QRZ Page
    Hello, I was looking into putting a mobile HF in my company car, I was at a Radio store and the saleman told me that it would be a 8 or 9 foot antenna. That probably would not look good on my company car, are there any other choices. I like to operate 40 meters and I practically live in my car traveling. Any ideas is appreciated..
    73 WD8G
  2. W0LPQ
    W0LPQ Ham Member QRZ Page
    Start here.
    www.k0bg.com
    Alan has lots of Mobile info ... you don't want a mag mount to start with.
  3. WA5BEN
    WA5BEN Ham Member QRZ Page
    Small antennas = HORRIBLE performance. I run the Icom IC-7000 with the AH-4 autotuner feeding a Hustler mobile antenna. I can operate on any band from 40 through 6 using a 20 meter resonator -- and use the 40m resonator only when I am operating "mostly" on 40. The "Backpacker" antenna or a "Hamstick" would also work -- but not nearly as well.
    In my case, the radio and the tuner are in the trunk, on a COMMON ground.
    My suggestion is to get a Hustler, cut and screw together the mast so that you can fit it in the trunk (unless you have a trunk that will take a 4 foot mast, when folded), and use a low-profile 3/8-24 mount. You MUST have a good ground.
    The AH-4 is a TRUE Antenna Tuner. (In other words, it MATCHES the ANTENNA to the feedline -- instead of "flattening" the network of feedline + antenna.) Any "tuner" that is inside a radio is NOT a tuner -- it is truly a "line flattener", and is highly inefficient.
  4. N7ZAL
    N7ZAL Ham Member QRZ Page
    I've used the Hustler with three resonators ( 40, 20, 15) and it seemed to work as well as any other mobile antenna.
  5. KC8HEF
    KC8HEF Ham Member QRZ Page
    hey are there any thing for 75meters
  6. NI7I
    NI7I Guest
    check out HI Q. The HI Q antennas are similar to screw driver antennas but better than most and, of course
    a bit spendy. I dont think you can find a better mobile/multi band antenna. No tuner/coupler required.
    Lee
  7. W8WLC
    W8WLC Premium Subscriber QRZ Page
  8. KD9ILL
    KD9ILL Ham Member QRZ Page
    My husband "K9ILL" runs a Wilson (FGT-2) 11 meter antenna on his 18 wheeler with a 1.1.1 swr on 20 meters and with a tuner, also works 15 and 17 meters. The Wilson FGT-2 is only 2 feet tall and comes with a 3 inch whip. Remove the 3 inch whip and replace it with a 40 inch whip and prune it down to resonance on 20 meters. You should wind up with about a 34 to 37 inch whip to get 1.1.1 swr on 20 meters. You'll wind up with about a 5' antenna and talk nationwide. 73...KD9CFJ
    G0RCN likes this.
  9. WB5YIW
    WB5YIW Ham Member QRZ Page
    I use a modified cb antenna as well. A company called Truck Spec markets one called Terminatior II. Its ugly but a remarkably good antenna. Has great broad band characteristics and by changing whip length you can change bands. For instance, I added a 60 inch whip and moved it to 15 meters. With a tuner, I also use it on 20. It retains its broadbandedness (is that a word?) over the entire general phone segment on both bands. Now I basically use the tuner as an antenna switch. Contacts have been made world wide on 20 and 15. I have another one mounted on the other side for 10 meters. They work well.
  10. G0TZE
    G0TZE Ham Member QRZ Page
    im using a Little Tarheel II Screwdriver antenna very happy with the results im living on the south coast of the UK G0TZE/m
