I've been leasing cars for a while, but finally bought another home about a year ago and now my lease is up. Since I can't damage the car, I didn't install a radio in the lease. (HT and a mag mount) So now that I bought a truck. I want to install a radio in it, but now I'm concerned about how to deal with the antenna given I keep my truck in the garage. I've heard of these fold overs, but I heard it creates a poor connection. Obviously a mag mount is still an option, but just like the fold over. If I'm already driving, all the sudden I have to pull over to get the antenna in a usable state. What do you garage parking hams do?
The solution depends on how much performance you expect from the antenna. If you are in an area where the stations you hope to work are all nearby, then a glass-mounted dual-band antenna on a non-moving portion of your rear window might just do the trick. I've used one for years, and it meets all my needs. My opinion is that Larsen makes the best, with great performance and reliability, but it's priced out of the 'budget' category. Probably worth it, in the long run. I've been satisfied with my MFJ, however, and I can recommend it for its good-enough performance and very reasonable price. It can be mounted just low enough on the window so it doesn't bump anything in the garage or the door, but it's very flexible if it does. Be aware, though, that modern vehicles may have a coating on (or layer within) the glass to reduce cabin heat from the sun, and this may block the inductive coupling between the inside and outside portions of the antenna's base. Not just tinting, it may be clear, although aftermarket tinting is also likely to interfere. I'm no expert on which models do or don't, so you'll need to research for yourself, if you decide to use one of these antenna. Best of luck with your choice, let us know what you decide to do! Cheers, David / N2PQW
Personally never heard of anyone having connection troubles with foldovers. But I always used quick disconnects on my whips. I prefer to have an antenna that performs well and accept the slight inconvenience. I would just stop as soon as I pulled out of the carport or right before I pulled in.
I'm not a super social person (generally prefer solitude to large social gatherings) and do not usually partake in general rag-chewing. I use my radios normally if I hear a conversation I'm interested in participating in, (interesting subject matter) or if I'm reaching out to someone for whatever reason. I'm a ham because I like the technology behind radio. Normally if I'm in the car, I'm listening to music, lectures or audio books. So, odds are very high, I will not expend the energy every morning and evening to connect / disconnect an antenna as I'm arriving / leaving home. Especially if I may go a week or even weeks without using the radio. (week(s) most likely if I don't have a connected usable antenna) The less convenient it is to use, the less likely I'm going to use it and hence why I'm asking here for a good solution where I can just turn on the radio and use it.
