Mobile Amp installation
Discussion in 'Mobile Radio' started by WB5PBS, Jan 10, 2014.
  1. N1GMV
    N1GMV Premium Subscriber QRZ Page
    I used to run (8) MRF-492's in my amp mounted in a 1987 Camaro Z28. I used the Hustler High power coils on the fold-over mast.
    Blew out 105 amp altenators twice, ran second battery in back, 2 guage wire to the front battery.
    500 watts is not too bad but still I don't recommend you key up when you are at an idle. You will fry the altenator. Would be best if you can run external diodes and a 300 amp altenator like they use in Ambulances.
    Be careful on 40 meters, I hear if things are not right you can deploy an airbag.
    PS> fun as hell to bust through a pile up of big guns while in your mobile and get a 20db over S9 report from the DX station.
    When you do make sure you toot the horn to let everyone know your mobile!!
  2. K8LLC
    K8LLC Ham Member QRZ Page
    I read your note hear, is there an outfit that has alternators that would handle a 300 watt amp?.
  3. W5LDA
    W5LDA Ham Member QRZ Page
    My 2013 silverado has a 135 amp alternator. I also run a TS 480 although a sat model along with the ALS 500 amp. Ran this setup in 5 different trucks with no problem yet. I might add I use a screwdriver built by KJ7U which will handle 600w..
