MJF 949D Versa II Deluxe Antenna tuner
Discussion in 'General Technical Questions and Answers' started by AXEMAN, Feb 1, 2021.
  1. AXEMAN
    AXEMAN QRZ Member
    Hi All,
    I'm beginning in Radio Ham, I bought a MJF 949D Versa II Deluxe Antenna Tuner, the problem is the power lead is missing for the Meter Lamp, I could make one but for the socket, I have tried 3.5mm jack plug, a small barrel plug, I can't tell what it is, sorry for being a bit thick, just starting with electronics.
    Does anyone know the connector for the Meter Lamp that goes in the back of the box?
    Many Thanks in Advance
    Stuart
  2. N3PM
    N3PM Ham Member QRZ Page
    Most of the pictures show a 2.5 mm plug is necessary, probably mono with the tip positive.
    Mike N3PM
  3. W3TKB
    W3TKB XML Subscriber QRZ Page
  4. KE0ZU
    KE0ZU Ham Member QRZ Page
    Perhaps the manufacturer has a solution. Consider contacting their customer service department, the call is free.
  5. NN4RH
    I've owned two MFJ-949E (same as 949D but includes dummy load) over the past 20 years.
    I think you'll find that the meter lamp is not really necessary unless you're going to be operating in low light. The tuner works fine without the light.
    The manual says it's a 2.5mm plug with center pin positive.
  6. N3PM
    This is what mine looks like- DC-Lamp-Power-Connector-MFJ-948-MFJ-949B-MFJ-949C-MFJ-949D-_57.jpg DC-Lamp-Power-Connector-MFJ-948-MFJ-949B-MFJ-.jpg
    Mike N3PM
  7. AC2QH
    AC2QH Ham Member QRZ Page
    The plug you show is a mono audio plug, sometimes called a "micro-mini". The tuner jack is a "coax" DC socket with a 2.5mm center pin. The DC plugs come in several shell lengths with both 2.1mm center diameter and 2.5mm. Many 12V DC wall warts use the 2.5mm variety and could be used to power the lamp, or you could salvage the plug and cable from one and connect it some other source of 12V. Some manufactures reverse the polarity and make the shell positive and pin negative, so check polarity before connecting.
  8. N3PM
    The jack shown is part of my 949D. It is not coaxial. Many MFJ units use a 2.5 mm mono audio plug to deliver power.
    Mike N3PM
  9. AC2QH
    With MFJ all things are possible. Mine uses 2.5mm coax. Go figga...
  10. KA9JLM
    Those can be very dangerous if plugged in with power applied. Because there is a instance of a dead short that is not all that good.
    A station power supply could smoke the wire when the tip gets welded to ground. :oops:
    Coaxial Tip + is the good norm now a days. Then you can have the confusion of OD and ID to deal with. :)
    One problem with the meter lamps, Many are made for 12V not 13.8V so life of the bulbs is shorter. Plus the meter can melt. 9V should be good enough.
