Microwave Power
Discussion in 'General Technical Questions and Answers' started by WA9SVD, Jan 9, 2018.
  1. K8ERV
    K8ERV Ham Member QRZ Page
    Misc: Yes, Sharp had the first turntable, think they called it a Carousel. Did not heat more evenly than the previous
    "stirrer" in the ceiling, but became popular cause it showed something was happening.
    Raytheon was a major developer/supplier of the early Radar equipment in the latter days of the Great War. After that they made radars for boats. Don't know about airplanes. But they wanted to use their expertise and hardware to get into the domestic (home) market, something they were not very good at. They licensed Tappan and together produced the "RadarRange, a large, heavy, powerful, and expensive ($1,300) built-in wall oven. Used 220 volts. We made about
    7 per day. Dick Tappan said it was not a money-maker, but helped to build Tappan's image as being progressive.
    This oven was introduced at a show in NYC in the summer of 1955. I joined Tappan in Jan 1957 to continue the development. Later Raytheon acquired Amana,, primarily a refrigerator company. They developed the first 115-volt
    countertop oven and the rest is history.
    TOM K8ERV Montrose Colo
    WB2UAQ likes this.
    Wow, great history!
    In 1957 I was five or six years old and we sure didn't have any microwave ovens. I think the first microwave I ever had was in 1974 when I bought my first house, and it didn't "come with one," I had to buy it.
    Today they're throwaways. My last one that died never failed electrically (Panasonic) but the door latch broke and surely wasn't worth repairing, so it's living happily in parts (brought it to a recycling center for appliances) in various landfills probably. Its replacement cost $179 at Costco. These are now Baofengs.
    Tom, how did Thermador (or anybody) make a wall oven/microwave like the huge one we have as a built-in? It can go to 550F using the electric heating elements, the interior walls are easy to clean (it has a self-cleaning function that gets much hotter than for cooking and just burns off anything on the interior surfaces turning it to powder you can just wipe away with a sponge), but is also a microwave in the same chamber. How did they pull that off?
  3. K8ERV
    I have been out of the field (retired) for 30 years and have not kept up with any recent developments.
    I don't know anything about the Thermador. We did try to develop a combo microwave/convection oven but the
    project was not hot (pun) and did not get far.
    I marvel at the low cost of ovens today. I have seen magnetrons being made and evacuated. Must be costly.
    We paid TI $75 for the first touch control panels, now you can buy the whole oven for about $50.
    Here they practically give ovens away at yard sales. The last one I bot cost $3!! Or to be publically correct $2.99.
    I got a full size high power oven with a very minor mechanical problem at a sale for free. Hard to beat the price.
  4. WB2WIK
    At our office we have about eight microwave ovens for use by employees, in the lunchroom. There are so many because 20-30 people at a time might be taking a break. And of course, they're also cheap!
    One of them "broke" at least a year ago in that it will continue to operate (full power) even with the door open. There must be an interlock that just isn't working. So, everyone makes sure it is OFF before opening the door.
    But I put a sign on the door: CHERNOBYL
    Some people got it.
  5. KW4TI
    KW4TI Ham Member QRZ Page
    Of course (this is very dangerous, so don't try this at home kids!), microwave oven transformers, diodes, and capacitors are useful for making other high voltage sources as well. Here is a Tesla coil I have built using two microwave oven transformers with a voltage doubler:
    Dan
    KW4TI
  6. K8ERV
    That is very strange. By law there must be at least two independently operated (no single mechanical failure can disable the system) and a "monitor" or "crowbar" switch that operates oppositely than the door switches and disables the oven if both of the door interlock switches fail to turn off the current. The crowbar usually shorts the power AFTER the door switches operate so put a short on the line, blowing the internal fuse. Hard to believe all three switches failed.
    These switches must operate properly for 100,000 door cycles.
    You should contact the manufacturer, he must correct the situation free. Unless the law has changed.
    I, and many others, have put our hands inside an operating oven with no harm. They just get warm in about 5 seconds and you withdraw them.
    I have heard that Glen put his head inside an operating oven, which explains a lot.
  7. K8ERV
    Dan, that was really neat! You are sure smarter than I am.
    But that's not too difficult---
  8. KW4TI
    It's dangerous, but its common to build Tesla coils using two microwave oven transformers (rather than the neon sign transformers, which are becoming less available) to provide the primary voltage, with the grounds of the transformers connected together, so that together these produce 4200 VAC. Then using the two microwave oven capacitors and diodes, you can get about 10-12 kV peak voltage to charge the Tesla coil primary capacitor. The hard part is that back EMF from the Tesla coil primary into the power supply when the spark gap arcs tends to destroy the microwave oven diodes, so you can use doorknob caps or a "Terry filter" to absorb these RF spikes. I use four microwave oven diodes in series rather than two potted in epoxy to prevent flashover.
    The microwave oven transformers are quite dangerous as they usually can generate well over 250 mA @ 2100 VAC which can easily kill someone, so the high voltage must be treated with extreme care. Also, I have bleeder resistors across the capacitors to make sure that for some reason if the internal resistors don't discharge, the capacitors don't remained charged.
    It's a comparatively cheap way to get high voltage because you can often find old microwave ovens at thrift or junk stores, and usually it is not the transformer, capacitor, or diode that is the problem, and so these can be recovered. I have wondered if these transformers might provide enough power for a tube amplifier.
    Dan
    KW4TI
  9. K8ERV
    Sometimes you may find ovens in a scrap yard. Sold by the pound.
  10. WB2UAQ
    WB2UAQ Ham Member QRZ Page
    Hi Tom
    I am a volunteer at the Antique Wireless Association in East Bloomfield, NY. One of the projects I am starting to work on is a magnatron display for the military collection. The idea started when I came across magnatrons from WW2 that were brought in from a member's collection many years ago. I have one book on the radar written by Ridenhour who worked at MIT's Rad Lab. Do you gave any suggestions for reference material that covers the history of magnetrons that could be useful for us? Thanks! 73, Pete
