Microsoft will be shipping a Linux kernel with Windows
Discussion in 'Computers, Hardware, and Operating Systems' started by KX4OM, May 6, 2019.
  1. K1SZO
    K1SZO XML Subscriber QRZ Page
    No way! That's what sudo is for. Even if it means "sudo su -" to become root after logging in rather than running a command as root.
    I always disable sshd from allowing root to login as one of the very first actions I take on a new box. (if it's not already) The most common brute force login attempts are made against use root. I run denyhosts to block any IP that attempts to login with root on the first attempt also.
    Also, never use david, bob, jim, or whatever else as a username. Those are the second most common brute force attacks. First initial last name is far safer because there are infanitely more combinations that a brute force hacker would have to try on top of all the password attempts.
  2. KK4NSF
    KK4NSF Ham Member QRZ Page
    That is a legitimate concern with both companies. I've got an Oracle Linux machine here for development work, and it's a decent OS.... I've got no problem with it. But I do foresee a time when the OpenSource Movement has been gobbled up by big companies and the code gets monetized without compensation to the thousands of contributors. It concerns me too. That's why I have a huge collection of source code. It's my Ark.
    K1SZO likes this.
  3. KK4NSF
    agreed.... but then again, if a machine not part of an external network (like the Internet), it's very hard to hack.
  4. KA9JLM
    Really. You have to change your name ?
    If your name is Root you may want to change it to RoOt.
  5. KK5JY
    KK5JY Ham Member QRZ Page
    WGates was taken.
  6. KT1F
    KT1F Ham Member QRZ Page
    That's probably all good stuff but one of the most important things you should do is disable SSH login by password. Using a key should be only way.
  7. W7UUU
    Yep - it's "WGates" and "password123"
    :D
    Dave
    W7UUU
    KK5JY likes this.
  8. VA3VF
    VA3VF Ham Member QRZ Page
    You forgot the capital P.:confused:
  9. W7UUU
    Oh! Right! Now it's secure :D
    Dave
    W7UUU
  10. WA9SVD
    WA9SVD Ham Member QRZ Page
    How about "whatever" and "else?":confused::rolleyes:
