MFJ 490 Keyer to FT-818/818ND
Discussion in 'General Technical Questions and Answers' started by G0TUE, Apr 15, 2021.
  1. KG7WGX
    When you go to Function Row 10 in the FT-818's menu, does the little ">" icon show next to KEYER above Button C?
  2. G0TUE
    G0TUE Ham Member QRZ Page
    I have made a video
    does this help explain my issue?
  3. G0TUE
    yes, my other keyer works, and just plugging a paddle in and using the internal keyer works.
  4. N3PM
    N3PM Ham Member QRZ Page
    Have you explored the 490's internal jumper?
    Mike N3PM
  5. G0TUE
    No not yet, but it's brand new, should be set for modern rigs, according to the manual? but as a final check
    I will explore that option.
  6. WB2WIK
    I'd try two things:
    First confirm 'OUTPUT TUNE' works:
    That should key your rig and send a steady carrier like a straight key continuously closed.
    Also confirm the OUTPUT is actually turned 'ON' and not OFF:
  7. W4NNF
    W4NNF XML Subscriber QRZ Page
    I don't know about this particular keyer, but the MFJ 495 I have has a jumper you can set for use in grid block keying. If that jumper is set, it will not key a "modern" transceiver.
    But likely is what WIK pointed out: turn the output on. For some (bizarre) reason the default out of the box is OFF....and you'd think they'd mention that first thing in the manual. Nope. I was scratching my head for quite a while when I got mine before I figured that out. :confused:
  8. G0TUE
    Output tune puts the keyer tone, but does not key the rig.
    output is on - tried off and on - keyer send command in cw.
    Ray
  9. G0TUE
    Eventually I found this, but that's not the issue.
  10. G0TUE
    no jumper that I can see
