SOLD MFJ-1835 Cobweb antenna
Discussion in 'Ham Radio Gear For Sale' started by W8DU, Jun 12, 2018.
  1. W8DU
    W8DU XML Subscriber QRZ Page
    For local pickup only (Metro Detroit)....
    This is a great antenna for Field Day, as well as permanent installation.
    I have for sale a HF cobweb antenna by MFJ. This is built to last and works great. Only selling because I upgraded to the bigger model cobweb, also by MFJ. This is hard to beat for HF ease and efficiency.
    The MFJ-1835 is a compact five-band loop array especially designed for limited-space installations. Using horizontal polarization, it packs a 3-4 dB gain advantage over ground-independent verticals plus superior immunity to local noise and RFI. In addition, MFJ’s highly efficient Spider-Match® network and adjustable tuning tabs guarantee low minimum-SWR on every band. The MFJ-1835 only measures 9-feet on a side, yet it features a full half-wave element on every band for no-compromise DX performance -- even when running QRP! The MFJ-1835 is solidly constructed to take on extreme weather. With sky-gray fiberglass spreaders and stranded-wire elements, it blends in with any backdrop. Best of all, it’s omni-directional, so you can omit the rotor and mount it high in the air using standard low-cost TV-antenna hardware.
    The manual is attached.
    If you want this great antenna, particularly for a small city lot, please email me. Please DO NOT reply here or send me a qrz.com message because I don't check those very often. Price is $150. Local pickup preferred.
    Tnx es 73 de Arnie W8DU.
    KA8UGB likes this.
  2. W8DU
    I almost forgot....I have the high-power balun from MFJ that will convert this to handle a full 1500 watts. There are also instructions for adding 6 meters to this antenna. MFJ also sells an add-on kit to add 40m and 30m to this antenna.
    tnx fer looking....73 de Arnie W8DU
  3. N4GCP
    N4GCP Ham Member QRZ Page
    Hi Arnie,
    I sent you an email using your QRZ-listed address.
    Many Thanks and 73,
    Earl N4GCP
  4. W8DU
    SALE PENDING.
  5. W8DU
    SOLD. Thanks fer looking.
    73 de Arnie W8DU
  6. QRZ
    Important Rules
    Have you read our Swapmeet Safety Rules?
    This forum enforces a set of buying/selling safety rules for the benefit of all users. Make sure that you're familiar with the rules before posting or replying in this area. Our moderators review every post in this forum and will flag or delete those that do not conform.
ad: Schulman-1
