MFJ-1708 SDR Problem
Discussion in 'General Technical Questions and Answers' started by F4HSQ, Mar 30, 2018.
  1. F4HSQ
    F4HSQ Ham Member QRZ Page
    Hi all ,
    I have recently received this item in good conditions , but using it : problems :(
    First I installed and connected it correctly ( ic-706mk2g and SDRplay RSP2 and 12v vdc)
    Reception : when connected , reception falls from S9 to S1 on the SDR.
    Transmission : power input 4 watts , power output 200 mW ! ! !
    This big attenuation is abnormal , and i cannot use it.
    Have you an idea , a solution ?
    Many Thank's
    F4HSQ
  2. F4HSQ
    I answer to myself :)
    A precision : tests have been done on VHF fréquencies.
    On HF , it's not catastrophic,but ...
    Conclusion : it's a rig of poor quality , made with an ordinary relay ( not a coaxial relay)
    If you want to destroy your SDR receiver , use it ! :mad:
    73's
  3. W5DXP
    W5DXP Ham Member QRZ Page
    I have an RTL-SDR V3 and it works very well. I run 30 watts output for PSK31. I accidentally turned on transmit while the SDR dongle was still connected to the transmission line. I chastised myself for such a blunder (not my first) and expected to have to spring for another $21 SDR dongle. To my complete surprise, the dongle was apparently not damaged and continues to function. I calculate that the dongle survived almost 40 volts on its input.
  4. F4HSQ
    Thank you Cecil for your answer.
    The problem here is not the resistance of your dongle ( $20) ; my SDR RSP2 Play costs $200 ! ! ! and i want to avoid an accident ! ! !
    The very big problem is that this device has an enormous attenuation in VHF / UHF and is thus absolutely unusable on these frequencies , and that MFJ is silent about this important subject and limitation , that is not honest.
    MFJ quality ? perhaps 20 years ago.
    I emailed MFJ : no answer !
    This rig could be a little more expensive , and built with a real coaxial relay inside, and not with this basic relay without insulation HF
    Conclusion: for the price , do it yourself with radio components and a true coaxial relay !
    73's de F4HSQ
  5. KA9JLM
    There is not much that can go wrong with it. Is the relay working ?
  6. F4HSQ
    Thank you for your reply.
    The relay is working , but this relay is of very bad quality : it is a simple commutation relay , not a coaxial relay .
    The insertion loss is VERY important up 50 MHz.
    MFJ forgets to specify this important information : unusable on VHF/UHF.
    Other surprising point : 200 W PEP input : I don't dare ! ! ! !
    About schématic : MFJ-1708SDR has a strap , not mentionned .
    73's
  7. KA9JLM
    It does look like they made a change to the schematic.
    I seen no info about frequency range.
  8. F4HSQ
    I asked a question on MFJ reviews website. about 1708SDR.
    Question 1 : frequency range ?
    Question 2 : insertion loss on vhf/uhf ?
    Wait and see ...:)
  9. K8JD
    K8JD Ham Member QRZ Page
    I could not find any mention of usable freq range in the 2 page info sheet !
  10. F4HSQ
