ad: Alphaant-1
Max bandwidth of 3.2768 mHz Cohn ladder filter
Discussion in 'Homebrew and Kit Projects' started by KA9P, Nov 19, 2021.
  1. KA9P
    KA9P Premium Subscriber QRZ Page
    I've been building up some 4 pole Cohn ladder filters from 3.2768 mHz clock crystals (the really stubby ones) and the filters look great but using 47 pF caps, I get a 350 Hz bandwidth, and going down to 10 pF I'm getting a 1.2 kHz bandwidth.
    I'm wondering if this is a frequency-related thing, a crystal-related thing. a topology-related thing, or a constructor-related thing :)
    Any thoughts would be helpful - is there a different topology that is more suited to broader bandwidths maybe (assuming I haven't messed up).
    Thanks Scott ka9p
  2. VK2CLF
    VK2CLF QRZ Member
    From a Youtube video I watched recently(*), it is normal for a Cohn filter to show smaller bandwidth with larger capacitors. I expect the filter input/output impedances will change also, and there will be limits on how far you can stretch things. If you want much wider bandwidth I expect you'll need to use higher-frequency crystals (for the same Q) or just different crystals.
    KA9P likes this.
  3. KA9P
    VK2CLF said "If you want much wider bandwidth I expect you'll need to use higher-frequency crystals (for the same Q) or just different crystals."
    Thanks much, yes, I'm afraid that seems to be the case.
    Unfortunately I'm back fitting filters into a 3.2 MHz IF strip from the receiver I wanted to build when I first started out half a century ago when you could get FT-243 xtals and build a half lattice filter. I guess the upside is the CW performance improvement is amazing. I did learn that Wes Hayward apparently had success getting an SSB Cohn filter in that range by paralleling inductors with the crystals, so I'm trying to chase that article up - might get lucky. Thanks, S
