Mating iMac Pro to IC7410 & Signalink USB
Discussion in 'Mac Ham Radio on macOS & iOS' started by WU7X, May 20, 2016.
  1. K3DCW
    The uninstaller.sh file is not a document to cut and paste into Terminal, it is a script and should be executed. To run it, simply copy the file to your Downloads directory. Go to Terminal, type
    cd Downloads
    sudo ./uninstaller.sh
    Enter your password when it requested.
    This will remove the drivers, if it is installed.
  2. K3DCW
    No, that is just what they call the file; it isn't installing the installer. The installer file can have just about any name. It has nothing to do with the cu.* thing or anything else. It is just a file name.
    So, disconnect the rig from the computer. (completely, don't just turn it off, remove the USB cable) Run the uninstall script. Reboot. Run the installer. Reboot.
    Open Terminal and type
    cd /Library/Extensions
    ls *.kext
    Do you see a file called SiLabsUSBDriver.kext?
  3. WU7X
    WU7X XML Subscriber QRZ Page
    Don't think it worked. Same issue with not being able to type in password over icon of key I think.
    I tried it twice. Second time didn't see the type in password request.
    This is what shows up in Terminal.
    Last login: Tue May 24 17:26:56 on ttys000
    iMac:~ daleavery$ cd Downloads
    iMac:Downloads daleavery$ sudo ./uninstaller.sh
    sudo: ./uninstaller.sh: command not found
    The uninstaller.sh shell shows up in the Downloads folder.
  4. K3DCW
    In the Terminal, type the following:
    cd Downloads
    ls *
  5. WU7X
    Sorry. I missed your second comment prior to working on the first. So this time I opened Terminal after rebooting the Mac and typed in what your requested. This is what comes up:
    Last login: Tue May 24 17:35:57 on console
    iMac:~ daleavery$ cd /Library/Extensions
    iMac:Extensions daleavery$ ls*.kext
    -bash: ls*.kext: command not found
    Notice that I am constantly getting the "command not found" statement. What's with that?
  6. K3DCW
    ls *.kext
    There is a space between ls and the *.kext
  7. WU7X
    Last login: Tue May 24 17:37:55 on ttys000
    iMac:~ daleavery$ cd /Library Extensions
    iMac:Library daleavery$ ls *.kext
    ls: *.kext: No such file or directory
    So now we know that I still have not gotten the driver downloaded properly.
    Let me start over.
  8. K3DCW
    I don't know what this icon of a key thing is. Are you running under a restricted account of some sort, or is your account an administrator account? I can't think of anything that matches your description.
    If the kext is not there, then the driver is not installed.
  9. DL2RUM
    DL2RUM Ham Member QRZ Page
    In the first step ou have to type: cd /Library/Extensions
    Note the slash between Library and Extensions.
    Code:
    Last login: Wed May 25 13:59:03 on ttys000
    MBA13:~ dl2rum$ cd /Library/Extensions
    MBA13:Extensions dl2rum$ ls *.kext
    FTDIUSBSerialDriver.kext:
    Contents
    K3DCW likes this.
  10. K3DCW
    Good catch, Tom. I didn't see that. Definitely won't work if you don't have the correct commands :)
    As I said before, Dale, open Terminal and type
    ls *.kext
    Better yet, copy and paste each line one at a time...those "/", ".", and spaces are all important.
